Posts: 1,201 |
http://contour.org/cgi/ultimatebb.cgi?ubb=get_topic&f=6&t=002401 That's all I could find in the search. Could somebody give me an exact measurement of their bar so I can try to find an alternative. TIA
If it's true that we are here to help others, then what exactly are the others here for?
Posts: 1,421 |
i talked 2 omp a couple days ago and they said they're working on a rear strut brace 4 us
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 2,066 |
Guys, Not sure about a rear bar, there are three that I have seen. 1) Made by SHO shop 2) In a magazine I ordered from Tuning Zubehor. Red Steel can't recall the price, they had matching front and rear. 3) Same magazine but in aluminum, they had matching front and rear. You should really give them a call and order there magazine, especially if you have a BMW or Audi talk about mad parts!!!! Its like 550 color pages. Releatively cheap too. Anyways not sure about the Aluminum vs Steel, I am pretty sure you will loose some weight but would only be compromised by stiffness. But I'm not sure to what degree. Let me know if you need any more info. Peace!!
Posts: 1,003 |
I would buy from OMPWINS over Driving Impressions any day of the week. Take it from a former Driving Impressions employee (me) that they do not have the bars in stock, and that it will take them forever to get enough of them in. I know how DI works, I have known the owner Bob Zecca for almost 8 years and worked for him for 1 before I quit in disgust. OMP is great stuff, but man DI can (and will) lead you on for quite some time with "it's almost here" or "it's in customs" before they actually deliver. They WILL come thru, but it's going to be a long time before you see the bars. Also, it's hard to beat $99 shipped from OMPWINS! Just my 2 cents...
Alex in Boulder, CO 95 SE MTX
Posts: 2,375 |
I havnt found a good bar for those who drive v6 tours so I decided to do my own (it helps to work at kirkhams (kirkhammotorsports.com) where I have access to a cnc. the comprimise from aluminum from steel is negligable and I am using 6061 T-6 alum. which actually is stronger than mild steel (used a lot in cars) which means that my sheet metal will bend before my bar will. and the alum is a third the density of steel so there is a definite advantage in weight.
Posts: 2,375 |
If I can get them to work then ill gladley make them for anyone who wants-
staytuned
Posts: 1,201 |
If they work I'm in for sure. Especially if they aren't friggin yellow. I haven't sent my money anywhere yet. Thanks for the heads up before I sent it in.
Posts: 2,375 |
I started milling the prototypes today- they will be alum in color. as for the center bar I will try both steel and alum. ill see which works best both packaging and effectivness. I plan on leaving the ends clear-coat and the center ford blue.
Posts: 463 |
horse> are you making the front or the rear bar???
Posts: 567 |
I have the OMP tuning Zuberhor polished alum bar, and it looks great! Only thing is, my local sho shop says it cannot be welded or bolted on for clearance purposes, so it is just wedged into place. Any ideas?
CURRENT RIDE: 95 GL FORMER RIDE: 99 SVT ( www.mysvt.com) "You only live once, but if you lived my life, once would be enough." -Frank Sinatra
