Posts: 1,812 |
ContourGuy, It'll bolt up to your engine and any catback system you can buy. Also, the pipe is not aluminum, but aluminized steel. Steel for strength, aluminized to resist rust.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 3,421 |
well will it fit or wont it fit Officer Cartman says it will only fit on a MTX..so whats the story will it fit a ATX
------------------ 99 SE SPORT Navy blue 2.5 ATX Moon Roof CUZO Hyper white high/low #885 BNM GAUGES KKM True Rev Magnaflow exhaust#14830 Ultraflow Res#17230 Contour windshield banner AIM#kajork2020
Posts: 3,180 |
Originally posted by I-Dom-In-8: well will it fit or wont it fit Officer Cartman says it will only fit on a MTX..so whats the story will it fit a ATX
You can mate it up to an ATX, but you need to add some sort of flex pipe to make it fit.. Paul from the UK did it on his Mondeo and really likes it, might want to check the archives for the specifics. But right out of the box, no it won't fit the ATX.
Posts: 337 |
Officer Cartman where did you get that list because I would like to get one if possible? Will Shoshop send one to me through the mail? If not I'll just print it off of here later.
Thanks 98 Silver Frost E0 CSVT
Posts: 2,061 |
I'm in for the stainless.
------------------ Dave Andrews Black&Tan 2000 SVT
Dave Andrews Black&Tan 2000 SVT 225 of 2150 Bassani.. UNCORKED davelandrews@comcast.net "Nothing is so firmly believed as what we least know." -Montaigne
Posts: 88 |
Originally posted by TheContourGuy: Will this fit a non-SVT?
Also, I would be careful with aluminum. It can't take high temperature really well. Stainless steel is much better. The aluminum might melt if it were used too much....
Really??? Aluminized steel is a pretty common material for exhausts and you shouldn't have a problem with the coating melting off... I had a coop at a steel mill that aluminized both plain-carbon and 409 stainless. One of their biggest customers of aluminized steel was Arvin-big OEM exhaust manufacturer (same guys that did the titanium mufflers for the Corvette ZO6). Just my 2 cents...maybe I'm smoking crack... ------------------ "00 SVT Silver Frost Davenport, IA
"00 SVT Silver Frost Sho-Shop Y Pipe Borla Exhaust KKM
Posts: 999 |
14.72@ 92.6 mph www.modularV8.com "CLUTCH KILLER" and also recently known as the DRIVETRAIN KILLER
Posts: 3,180 |
Originally posted by Appstate98SVT: Officer Cartman where did you get that list because I would like to get one if possible? Will Shoshop send one to me through the mail? If not I'll just print it off of here later.
Thanks 98 Silver Frost E0 CSVT SHO Shop faxed it to someone who scanned it in for the list.. If you call them, they could probably do the same for you.. Too bad they never update their website, some of this stuff has been available for quite some time.
Posts: 999 |
Posts: 703 |
count me as one
aluminized, hi flow cat.
Seeya FUseface "Superhero Extrordinaire" "I am Nigh-Invulnerable!" 97 LX Sport
AIM:MiguelAD8
