Posts: 116 |
If it's not to late count me in. 3 pod in Midnight Blue. Thanks, -Nate
~~~~~~~~~~~~~~~~~~~ 98.5 SVT ~~~~~~~~~~~~~~~~~~~
Posts: 62 |
Count me in for a triple replacement piece in midnight blue. kpicket@acad.stedwards.edu. Any idea what the price might be?
Kyle Pickett (Austin,TX) 98 SVT (silver) #860 of 6535 Eibachs/Konis 18" TSW SGVs-225/40/18 Sumitomos KKM intake/BAT inlet pipe KKM pedals Sho Shop pulleys B&M shifter/ATR aluminum knob mesh grilles Autometer shift lite SCA sidemarkers Hose Techniques SuperBlue hose kit Home-made rear STB
Posts: 258 |
The cost should be around $45. If you really look at the summit / autometer pods all they are is a stick on piece. You just use 2sided tape and paste it on your a-pillar trim panel. They are not very attractive, plus you have to accept that the gages are at a set angle and you may not be able to see them clearly. With the gage setup I am working on we will be able to see and customize the product before it is made. I will try and set up a meeting of anyone local to me to check out the mockup when I get it.
Please take everything I post with an MDOT trucks worth of road salt!  Please help control the TROLL population by getting them spade or neutered! 2001 Blk/Blk Cobra Previous owner of a '99 Cobra, and '00 SVT Tour
Posts: 1,296 |
What is "local" for you, onestep?
Tim
Posts: 258 |
Well I live in the Plymouth, MI area but I do like to drive my SVT Contour!!! So just about anywhere in the metro Detroit area is fine, as long as it is convienent for most folks.
------------------ All your problems and worries can be solved with alittle more throttle!
Anonymous
Unregistered
Anonymous
Unregistered
Tell you what, count me in, as long as it fits the gray color of my interior. 3 guage is great. Hopefully, someone can help me wire something into it when it comes.
------------------ '96 Zetech Limo Tint 1000Watt System
Posts: 0 |
lets say i have automatic transmission... what gauges can i put there??? JUST FOR LOOKS or whatever >:P hehehhe
------------------------- 95' Contour SE 2.5 Duratec V6 Teal Power everything 17" Enkei Suzuka
Pioneer Premier Deh-p900r Boston 5x7" all Autotek amps 2 kicker S12L7
(Wants to know a nice ground effect kit for this SE)
Posts: 258 |
What gages are out there??? Water temp, Oil temp, Trans temp, Oil pressure, boost pressure, engine vacuum, volt meter, ammeter, exh gas temp, air/fuel meter. Are there any others that you guys know of?
Posts: 744 |
just making sure, triple in grey twins
Black 99 SVT Ground Control Coilovers 19" KMC Tensions (Gunmetal)
Silver 98 SVT Ground Control Coilovers 19" KMC Suicides (Flat Black)
Posts: 1,217 |
Onestep,
Do you have timing on the mock up yet?
Mark
