Page 2 of 3 1 2 3
#256510 08/28/00 09:58 PM
Originally posted by Steve Bassen:
I'm in for that price if they get it done relatively soon
A 99 SVT is being fitted up as of tomorrow. Dyno test to follow as well as pics (I hope).
Chris
#256511 08/29/00 02:20 PM
Just wanted to say thanks for the frequent information and postings, Chris. I've got a few dollars that are just raring to jump out of my pocket, if the price/performance of the y-pipe is right!
JaTo
Overland Park, KS
JaTo@kc.rr.com
99 Contour SVT
#143/2760
Modded to Taste
00 Corvette Coupe
Modded to Haste
#256512 08/29/00 05:09 PM
Chris, did I understand correctly that you will also offer a 2 1/4 inch (exit pipe size) Y pipe? This would be better (I think) for us you have Bassini or Borla catbacks that are 2 1/4 in.
Dan
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#256513 08/30/00 12:07 AM
Chris has being really good to work with, very informative and flexible and took the time to ensure all questions answered and that everything would get done to the highest quality.
QUICK UPDATE, my SVT brought into the shop tonight (darn Explorer, I already miss the SVT, ) and they will start fitting the new pipe and checking its design over the next day or two to ensure everything is ok.
I still have the stock exhaust on my SVT at 2.25" and even with the 2.5 exit, the flang should be able to accomadate the smaller diameter, Chris will be able to give you better details probably.
I am not sure on the when I will have the dyno results, I have a road dyno kit that I just got so I will do a quick and dirty estimate b4 going to the dyno chassis and let everyone know by Friday how it feels.
alessandro
sILvER FROSt
Originally posted by cawong11:
Update: The new Y-pipe/High flow cat will be CTA Motorsports own and will be manufactured by a different shop, not SVTCONTOUR.com. Most of the help in getting this piece made up has come from Alessandro (Silver Bullet).
alessandro
PERFORMANCE FORDS- Unique parts for the contique and cougar
SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com
1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed...
177hp, 155lb-ft
#256514 08/30/00 12:33 AM
Dan
Dan
If we can find a 2 into one cat with the 2 1/4" outlet, then yes. Otherwise, the 2 1/2"flange is only marginally bigger and will fit the 2 1/4" flange of the Bassini and Borla exhaust. In fact, I had the 2 1/2" flange tested on my SE when I still had stock 2" pipe and it fit the 2" flange.
Chris
#256515 08/30/00 12:35 AM
JaTo
You're very welcome and I'm hoping for good, no great, results.
I or Alessandro will post the dyno numbers when we get them.
Chris
95 Contour SE (200HP all bolt ons)
#256516 08/30/00 12:34 PM
W
W
This is a simple bolt on mod, right? No welding or anything else that would make it difficult?
If so, I'll take one!
#256517 08/30/00 06:23 PM
Thanks Chris, Im a little concerned that the 1/4 inch smaller catback might cause some turbulance but maybe not a big deal. Any thoughts?
Dan
#256518 08/30/00 07:15 PM
Can I get one without the cat?
David Z.
Silver E1 #4808 w/stuff
http://daplace.spedia.net
David Zambrano
svt_mondeo at yahoo dot com
CSVT E1 #4808 - soon to be 400hp
You get what you pay for. All advice here is free.
http://www.geocities.com/svt_mondeo- my homepage
#256519 08/30/00 10:50 PM
Dan
Difference is very little. No worse than say the stock resonator in the SVT exhaust, which BTW has a 2" inlet and outlet, not 2 1/4" FYI.
Chris
Page 2 of 3 1 2 3
Moderated by  1314_dup1
