Posts: 132 |
let me ask a few of you. I think it's the Thermostat, or the Fan. But today seeing its 90 outside. I came home and the cooloant was boiling out of the tank. I let if cool off fill it up with water and drive it one block and it's over heating again.... Which one does it sound like the most? I'm leaning to th efan because I have not heard it come one.....
1998 Sliver Svt... #1698 of 6535 K&N Filter Came on the earth on 6-6-1997
Posts: 1,773 |
w a t e r p u m p b a y b e e e
--alex | 96 GL(sort of) V6 ATX | 98 SE V6 MTX Sport
Posts: 72 |
Welcome to the wonderful world of replacing your water pump. BTW, try to avoid driving it at all until you get it fixed.
Posts: 1,537 |
Don't DRIVE it at all ! Don't even START the engine !
REPLACE THE WATER PUMP NOW !!!
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 1,196 |
What Pete said....
Also, when the waterpump gets replaced, get an aftermarket one with a metal impeller. The plastic impeller that the Ford OEM one tends to fall apart or wear down to oblivion, which is the reason the waterpump fails.
Matthew 98.5 Contour SE V6 It has spent 1.5 years under the wrong identity ;-)
Posts: 816 |
Why is it called a water pump? They should call it a coolant pump.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 1,040 |
... 'cause coolant (water/anti-freeze) wasn't invented yet.
