The Zinn's website has been down for a while now (those hosers
) so I haven't been able to post any links to their directions on their website .
I'll try to find their exact address somewhere on the web for you guys .
They're along route 272 in Denver , Pa ... which is right off the Turnpike . If you're coming down the turnpike , it's easy to find .
Get off the Turnpike at the
READING exit
exit 21 . Once you get off the exit , follow the signs to
rt 272 . Don't be confused when you see signs for rt 222 , it's right there too (don't get on 222) . Rt. 272 is only about 1/4 mile to 1/2 mile away from the TurnPike exit on a limited access road . When you get to the light at
rt 272 , turn
RIGHT . Go about 1/4 to 1/2 mile and Zinn's will be on your
LEFT . It's a small brown building with a big "Z" on the front of it & I believe a statue of a dutch dude in front . Eazy to spot ... right next to a Gas station too , just in case you drive past , it's on the same lot . DRIVE AROUND BACK , that's where we'll meet .
I'll post better directions VERY soon in case it's needed , although these should be fine .
Basicly in a nutshell:
Go down turnpike
Get off at
Reading exit (#21)Go about 1/2 mile towards rt 272
Get to rt 272 & turn right
Go about 1/2 mile
Look to your left & see Zinn's
Go around back & park
If you're coming up/down rt 222 , is basicly the same :
Go on rt 222 till you see the
rt272/PA TurnPike/Denver exit & get off .
Go about 1/4 mile towards rt 272
Go about 1/2 mile
I'll see what I can come up with on the address .
~~~~~~~~~~~~~~~Allen
