Today I did the front brakes, first did the left side put SVT sized rotors and calipers and bleed it. I took it for a spin and the pedal feel was fine.
Then I did the right side and bleed it again but this time the pedal just goes almost all the way down. I gotta pump the pedal a few times for it to hold at the top. There are no leaks or anything and if I press hard it holds but almost at where the brake pedal hits the floor mats. I bled the right side a couple of more times but still no luck
The other thing is that on the right hand side I can move the pads while the brakes are depressed (all the other corners are pretty snug)
What should I do? Bleed the whole system?
