also check you driveshaft boot is the platic ruber nearthe Knukle. I used to have the same problem at it was not the brake but the driveshaft boot leaking grease
"You can turn a engineer into a sale man but, you can not turn a sale man into an engineer" "I have walk to the valley of Honda and death for that I should not fear no V-tech"
99 cougar,SVT manifold convertion, Tranny upgrade by Haines Motor sports (Quaife lds, Fidanza flywheel, and Clutch Master Stage 3 clutch) 18" Axis Se7ends,GC coiovers,sho sho Y pipe,Wilwood4 piston brake kit
