Posts: 1,268 |
So what would be needed to bolt these on to a non SVT?
-Ken V. psycho_bass@hotmail.com My Car
Posts: 76 |
Would you be able to use the CSVT calipers with the FSVT rotors on a 2000 CSVT?
Posts: 3,237 |
Originally posted by TLaven: Would you be able to use the CSVT calipers with the FSVT rotors on a 2000 CSVT? I would say NO, as there is not enough room to house the 1" bigger rotor.
Posts: 2,848 |
quote: -------------------------------------------------------------------------------- Originally posted by TLaven: Would you be able to use the CSVT calipers with the FSVT rotors on a 2000 CSVT? --------------------------------------------------------------------------------
Not to mention it would defeat the purpose! As far as a non SVT goes...you can probably get away with the fronts, unless you have 4 wheel disc.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 517 |
So there is no need to change the caliper bracket right?
Posts: 2,848 |
Posts: 3,636 |
What about the back end.
Did you guys do any work with the rear calipers and rotors.
And I'd like to see those pics when you get 'em.
Brackets, will that be an issue for the E0 vs E1 vs Non-SVT. They can't all use the same caliper brackets.
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 3,248 |
Also, these brakes work with stock SVT wheels??
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Administrator
Administrator
Posts: 4,527 |
Caliper brackets are definately different, you will have to use the FSVT caliper brackets w/ the FSVT calipers.
I believe these do fit under the stock SVT wheels, IIRC I have seen a few Focus SVTs w/ CSVT wheels mounted all the way around (test vehicles on winter tires)
It's all about balance.
bcphillips@peoplepc.com
Administrator
Administrator
Posts: 4,527 |
One other item to keep in mind, no-one knows what affect fitting these brakes will have on pedal feel, in travel or in pedal force.
