Posts: 2,848 |
yes they will...a focus guy has a set of E1 wheels that he uses on his Focus SVT for winter. They fit under the wheels.
EDIT: I was lead to believe the Focus brakes are better than the stock contour...rotors might be the same size, but are the calipers not different? I need new rotors regardless...I'd like to get some extra stopping power as well, but nothing over the top (like an $800+ baer kit or something). If it's really not worth the trouble, can I get bigger rotors, or does anyone recommend the slotted/drilled BAT rotors? And perhaps some better pads (recommendations please)?
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 3,636 |
Originally posted by TheGreatOne: yes they will...a focus guy has a set of E1 wheels that he uses on his Focus SVT for winter. They fit under the wheels.
EDIT: I was lead to believe the Focus brakes are better than the stock contour...rotors might be the same size, but are the calipers not different? I need new rotors regardless...I'd like to get some extra stopping power as well, but nothing over the top (like an $800+ baer kit or something). If it's really not worth the trouble, can I get bigger rotors, or does anyone recommend the slotted/drilled BAT rotors? And perhaps some better pads (recommendations please)? Well they are bigger. The SVT specs are "around" 280mm rotors up front (some say 278mm) and ~253 rotors in back. So, essentially 11" up front and 10" in back. So, the SVT Focus has slightly bigger brakes. Dunno 'bout the calipers. TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Administrator
Administrator
Posts: 4,527 |
well, a friend said he will loan me an SVTF caliper and rotor for a test fit on the contour, so we will see.
It's all about balance.
bcphillips@peoplepc.com
Posts: 668 |
I'd be interested in a FSVT brake swap also.  I'll be needing brakes within the next year or sooner.
98.5 SVT#6092 of 6535 B/MNB Born on date 5/22/98 Y2K Suzuki GSXR 750 Y/B with 140.6HP
Posts: 23 |
Hey hold on before you buy those I was looking for some rotors for my Mystique and found a place that has Cross Drilled and Slotted rotors for our cars and wants $130.00 for the pair.
Call this Number 1-877-832-0194 EXT. 3291 Tell them You were told you could get rotors for $130.00 shipped. They look great! bolt pattern 4X108
Pacific Green 96 Mystique TSW Wheels Nitto Tires Sony Xplod System SVT Exhaust minus the Resonator (I sound Mean for a 4 Banger) SOON to COME Body Kit/ Underbody Lighting/ Magnaflow Mufflers
Posts: 2,848 |
Rara, be swift like lightning! I have an appointment at watkins glen on the 19th of august!
Administrator
Administrator
Posts: 4,527 |
lol, well, I'm gonna be out of town until tuesday, so likely it will be next weekend at best before I can find out.
Like I said, I'm pretty sure they will fit, but I'm going to verify.
fwiw, I may have a cheap source for these brake parts, and maybe some of the SVTF wheels as well if this all works out. (friend of mine races foci, and one of his sponsors gets him super cheap parts)
Administrator
Administrator
Posts: 4,527 |
Originally posted by GreenLantern: Hey hold on before you buy those I was looking for some rotors for my Mystique and found a place that has Cross Drilled and Slotted rotors for our cars and wants $130.00 for the pair.
Call this Number 1-877-832-0194 EXT. 3291 Tell them You were told you could get rotors for $130.00 shipped. They look great! bolt pattern 4X108 No, you see, we are talking about parts that actually IMPROVE braking performance, not just increase your pimp factor (which the Contour/Mystique is inherently low in anyway)
Posts: 39 |
In the June '02 "Muscle Mustangs & Fast Fords" magazine, they did an article on the SVT Focus. In the article they stated that the brakes were made specifically for the SVT model. They require a special steering knuckle to install on a regular ZX3 Focus. The article did not mention the Contour. However, I believe the regular ZX3 Focus and the SVT Contour share the same front brake design. This would indicate that the special (SVT) steering knuckle would also be required on the Contour. I've been meaning to call SVT and ask them about this.
Wife's car: '98 Contour SVT, black, drop-in K&N, no reasonator w/stock mufflers, Optima red top gel cell battery #0703 of #6535 My car: '95 Mustang GT, teal/gray cloth, w/Saleen body kit, 13" Baer brakes, GT-40 intake, Edelbrock heads, stock cam w/1.7 RR, 75mm Pro-M, 36lb injectors, custom JMS chip, MAC longtube headers, Vortech S-Trim (6-7psi), and way too many more mods to list... 382rwhp 379ftlbs torque with a very mild tune from JMS Visit www.sn95.com
Posts: 2,848 |
No, you see, we are talking about parts that actually IMPROVE braking performance, not just increase your pimp factor (which the Contour/Mystique is inherently low in anyway) LOL! Thanks Rara, I would also be interested in FSVT wheels in the future, though I'm not sure whenI I was qouted @ $175 a piece from Bill.
