Posts: 2,848 |
Since I'm in need of some new rotors...I figure some nice 11" rotors and matching calipers from the Focus SVT would be a good upgrade/replacement without shelling out mega bucks for a 3rd party setup. Question is...will they bolt right up, or are there any modifications needed, and if so, what?
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Administrator
Administrator
Posts: 4,527 |
I'm pretty sure they will bolt right up, if you get the caliper, caliper bracket, pads, and the rotor. But don't quote me, as I have not had parts in hand to try it with.
It's all about balance.
bcphillips@peoplepc.com
Posts: 2,848 |
Yeah i've been silently waiting for someone to try it, figure out the bugs, and tell us about them...but nothings happening so hopefully I will spike someone's interest!
Posts: 349 |
Wanna fund my interest. I'm espically interested as AEM now had a big brake kit that uses the stock calipes as well.
All you would need if everything bolts up is the FSVT calipers, and the AEM brackets and 2-piece rotors. I'm just excited about the possiblitly of bigger rotors/better performance without having to use spacers. Right now I'm not too impressed with my KVR rotors. They seem to like to expand at different rates when pushed hard on the track and warp, but after they cool down they are fine. Then again...maybe I need to stop going into corners so deep :rolleyes:
Evan Groenke 1999 Silver Frost SVT #1919 183.9hp 163.7lb/ft tq @ the wheels Now bitter at Ford
Posts: 2,848 |
any new info on this? I'm getting prices fro mbill jenkins, but I'm really hoping i won't be wasting time/money on this.
Posts: 1,003 |
If the rotor thickness is not much different than ours, you could possibly get away with only needing the rotors and the correct bracket to remount your calipers the correct distance away for the bigger rotor diamater. I know BAT is offering an 11" option for their Wilwood kit and my $ is on them using FSVT rotors for the kit...
Posts: 517 |
Aren't CSVT brakes almost 11"'s ?
Posts: 2,112 |
280mm, or yes, approx 11".
Posts: 3,636 |
SVT Focus brake specs from SVT website:
BRAKES Front: 300mm (11.8 in.) vented disc, single-piston caliper Rear: 280mm (11.0 in.) disc, single-piston caliper ABS: Four-channel, four sensor system
And for "TheGreatOne" you could probably safely buy them. If it doesn't fit, a trip over to the FocalJet boards.
Or even better yet, team up with someone over there who wants the brakes, and let them know what you are doing, maybe they will back you up and buy them from you if it doesn't work on your Contour.
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 82 |
Another big question is will they fit under the 16-inch SVT Contour rims?
98 Silver Frost SVT "I was doing fine until I ran out of talent." "It's not whether you win or lose, it's how drunk you get."
