Posts: 36 |
Just curious how long your pads have lasted you in the past?
d ~ 98 SVT E1 #6196 of 6535
Posts: 3,934 |
The ones that my car has have been on the car since I bought it at 77K miles. Its at 107K now, as of today.  I don't know what brand they are though. I have some Mintex A/Fs ready to go on it as soon as I get some cash together. I had to do the drums at 90K. They were Ford parts.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 2,657 |
My stock pads lasted until around 50-55K...I'm at about 83K on the Performance Friction pads I replaced the stock pads with.
Posts: 515 |
I'm still on Factory pads at 37K.
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
Posts: 291 |
I am still on factory pads at 68,000 miles  I got them checked at 60K and they said the pads are fine they have 2/3 - 1/2 of orginal thickness left so I was worried about them check again at 100K
2000 Silver SE Sport V6 MTX, B&M shifter, SVT exhaust, 75K on the clock.
Posts: 650 |
Replaced stock fronts with Baer big brake kit @32,000; I am now at 65,000 and still going(err, stopping, that is, strong. Rears are still stock as I have sworn not to change them until I replace the drums with discs.
A little off topic but does anyone know the replacement pads for the Baer's?
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
Posts: 31 |
My factory front pads lasted until ~77K miles, when I changed them bc of grinding. As I removed them, one of the pads just fell off the backing plate!
Posts: 125 |
64,400 kilometers, replaced all original pads. The front pads showed signs of wear and cracking across the surface. I could have gone longer on them, but decided in the interest of saftey to replace them. The rear pads were down to the thickness of a couple sheets of paper, and in fact self destructed when the caliper was removed for painting. CM.
99 Mercury Mystique V6 Black KKM, 9006 BV Bulbs, Painted Calipers, 16" Cougar Rims Alpine 7894, CDT HD62DT front, CDT Coaxials rear, ,Mmats Pro 10's. POS amp. No RICE.
Posts: 26 |
I had under 25k when I had the pads and rotors replaced under warranty. Rotors heavily cracked. The factory pads they put back on felt awful. A week later I pulled them off and replaced the pads With EBC Greenstuff and the Charred brake fluid. Less than 3 months later, the rotors are again being replaced under warranty. Again heavily cracked. I will post pictures soon. The EBC's apply alot more friction (heat) than the stock pads. Which is probably why something that took 2 years to accomplish the first time, the second only took 3 months. If you are staying with your stock calipers and want to increase breaking performance, go with the EBC pads. I have been very happy. Now I just have to find rotors that can take the heat.
2000 CSVT
Posts: 2,112 |
factory pads, almost 50k miles.
