Anyone who changes pads and rotors at the same time and then attributes the gain in braking "feel" to the rotors is missing the boat. You may even see the same gains from flushing your brake fluid.
Anecdotal evidence is pretty much worthless, here, and let's remember that the brakes don't stop the car. (It's the tires, man!) So better friction, etc. might give you better control, etc. but it won't stop the car any faster than your tires are capable of.
Drilling and slotting are a waste of money on a street car, which will never see the kinds of brake temps that might require such extreme measures. Either disc mod reduces one aspect of performance (disc mass) to solve another problem (out-gassing or glazing). In the same way that large ground-effects increase drag, reducing top speed, to allow a car to maintain higher speeds in the corners. It's a tradeoff.
Klee, you are definitely better off going with full-faced rotors and high-quality pads. I'm with Demon on this one.
You want real education? Start
here and then read this article about
common rotor mods.
