jng Offline OP
Hi,
Changed the front rotors & pads this weekend w/ ~81K miles on them. The hardest part besides getting the frozen rotors off, was getting the spring clip back on.
I know the backs are different, so just wondering if it is also a PITA, anything I need to worry about. Thanks.
N
N
well, to open the calipers on the rear brakes involves screwing them open and closed. The fronts can be opened by a C-clamp and forcing the brake piston to move. But the rears are a screw type, so you'll have to turn them to open the calipers. You'll see when you look at the piston. It's not difficult.
jng Offline OP
Almost forgot about that! I need to get a pair of needlenose pliers. Do the backs also have a spring clip like the fronts? Thanks.
2
2
Rears have a stamped steel spring that clamps on top of the shoes instead of a spring steel wire.
it sucked when i did my back brakes last yr (90+ degrees the day i did them)....i ended up leaving off the clips on the back and my brakes rattle like hell now....im planning on changing rotors n pads soon so i'll get new clips for the mis-dealer
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
Moderated by  Andy W._dup1
