Originally posted by hmouta:
i noticed that i'm getting rust not on the rotor but the section that is closer to the the wheel (very hard to explain). its a 90degree angle w/ the rotor surface, directly perpendicular. can i get rid of it.
If you get aftermarket rotors, some are coated so this area (the hub) won't rust. SVTs are like this from the factory.
-Louis
1998 Black E0 #3826, lightly modded
