Posts: 47 |
okoki saw a post on this awhile back but now i cant find it?? on my disk now that we are having rain im seein a good amount of rust starting to form!!! any suggestions on removing it and keepin it off?? thanks
2000 silver frost midnite blue csvt
Posts: 69 |
Use your brakes!! That will wear the rust off the rotors
98.5 Contour SVT - Silver Frost Cupholders - MP3 Deck - Sub - Painted Calipers (Silver) - K&N Filter
Posts: 31 |
My discs start forming rust as soon as they get wet. I guess you could paint the parts that aren't rubbed by the pads.
Posts: 268 |
My neighbors Corvette does the same thing. I don't know of any car that doesn't, except old Chevelles with front drums. As soon as you use your brakes it will rub off.
98 Contour SE Zetec ATX "Chevy Corsicas Fear me!"
"There's no such thing as a PRETTY GOOD alligator wrestler"
Posts: 52 |
Using the brakes gets the rust off immediatley, usually a result of very humid air, like after it rains or if you live near an ocean/body of water/etc. Could also buy a can of brake component cleaning stuff from an autoparts joint (made by 3M, what I use). Cleans the rotors and calipers well, gets rid of the buildup, and helps remove some of the rust buildup. Could just get cryopreserved rotors.
'98 Black SVT #651 of 6535 KKM Intake (Miks Heat Shield in Winters/Drop-in K&N Summers), SHO Y-Pipe, and Bassani Exhaust. Eibach Pro-Kit, Koni Struts, and Enkei RS5's with BFG-KDWs (215/45-ZR17) BAER 13" big brake kit+rear baer rotors all zinc washed, cross-drilled and slotted (Greenstuff binding rears) Kenwood head unit with Infinity reference speakers+1 8" Bazooka Tube fed by two MTX Blue Thunder amps. Hella Stage II HIDS from hids4less.com. Recaro Sport Seats trimmed in supple black leather. And Zymol wax to keep it squeaky clean.
Posts: 1,444 |
i noticed that i'm getting rust not on the rotor but the section that is closer to the the wheel (very hard to explain). its a 90degree angle w/ the rotor surface, directly perpendicular. can i get rid of it.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 3,950 |
That is normal for unprotected metal. BTW you need a shorter sig.
Posts: 117 |
All disks rust. As stated before, just drive it, it will wear off right away.
99 Black&Tan SVT #308 - For sale Borla Catback, K&N Blaupunkt '01 Audi S4 Avant yeeehaa!! 91 Audi Coupe Quattro- For sale 68 Mustang Convertible (summer fun)
Posts: 2,587 |
Originally posted by LoCoZetec2.HO: That is normal for unprotected metal.
BTW you need a shorter sig. But then how would we find out about his trunk cargo net? :p
1996 Contour "Mean Green" (99-02) 2002 Malibu Blue Focus ZX5 - something to hold the PB 15...
Posts: 1,444 |
the small stupid stuff in the sig is what i get the most pm'ed questions on, believe it or not. its the small stuff that most people overlook and need info on.
AIM:omegazodiac
