Posts: 1,444 |
slotted rotors are sweet.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 3,419 |
And long sigs that list fluids are ghey.
Posts: 4,042 |
Originally posted by hmouta: slotted rotors are sweet. Aaah yes. Nevermind the bigger swept area, thicker rotor, stainless steel lines, and 2-piston calipers, but the 'slotted rotors are cool'. :rolleyes: John
Posts: 4,042 |
Originally posted by PA 3L SVT: And long sigs that list fluids are ghey. Hey now, a non-personalized license plate and removed license plate holder are quite the mods. John
Posts: 1,444 |
Originally posted by Antonio Wright: The brakes look good. Just do not use any type of meguairs wheel cleaner on them becaues you will have major spots. I am taking my wheels of tommorrow to clean everything. That front needs to be tucked just alittle more...
P.S.. You got stickers!!
-Antonioyeah...DON'T use Mequairs to clean your wheels....it will stain your zinc coating...
Posts: 3,567 |
looks real nice.
The Baer brake kit is only for the front, right?
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 1,428 |
Thanks for the head's up on the wheel cleaner... I ususally clean them with the end of my car wash bucket and a separate mitt.. Should be fine with that huh? I know about the stance.. Putting the 18's back on this weekend I just didn't nail it right the first time, and then I had no time to jack it back up and reset it. Should be fixed this weekend. JSmith: Yup, only a front "big brake" kit. I have their OEM sized rotors to match my front setup though. With performance pads it should get the job done fine.. ..unless you're ShaunG or Antonio! :p
Posts: 1,022 |
Yea I was in a bad news. Wont believe what happened yesterday to my car.  anyways c-ya this weekend. Micah
97 Lx 3.0 MTX lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
Posts: 923 |
I have a thing for cargo nets.
Posts: 1,428 |
Originally posted by Stevers: I have a thing for cargo nets.  ..you use that to slow your car down?? Hey, will I see you this weekend? Going down to Plattsburgh on the 20th.. Jeff's coming, and other Montreal CEG people will sure tack along!
