#250877 03/28/02 08:28 PM
i purchased my 99 contour about 6 months ago the brakes were making a sqeaking noise and had alot of brake dust. we checked the pads and they were fine what could be causing this.
99 green se
#250878 03/28/02 09:53 PM
cheap pads or unclean rotors
98 SVT
MODS:
Something or another
#250879 03/28/02 10:29 PM
KJ Offline
Like biggy said it's most likely caused by the dust buildup. One thing I used to hate about the stock pads. Go get 17" rims and the Baer Track Kit. Takes out the squeak every time. laugh
Married the gal of my dreams 04.27.02 smile
2K SVT Black/Midnight Blue
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
Best Time 14.942 at 93.98mph
Car is now for sale - 14000
#250880 03/28/02 11:23 PM
There are several things you can do to minimize brake squeel, but it could return.
Remove the pads, sand the lining to remove any glaze. Use a very course sand paper. Lightly champher all edges of the pad with the sand paper. Scuff up the rotors with the same sand paper, or have the rotors machined. Remove the rotors from the hubs. Clean any rust from the surfaces where the hub and rotor mate. Gently apply anti-sieze compound to those surfaces. Make sure the caliper slide pins are working smoothly and are properly lubricated. Where the back of the pad backing plate mates with the caliper, either treat with anti squeel goop (preferred) or lubricate with disc brake grease. Also lubricate the pad backing plate at any point that it touches the calipers. Reassemble.
The most critical part of all this is the proper lubrication of the brake pad backing plates. Unfortunately, often the most neglected part of a good brake job.
Jim Johnson
98 SVT
Moderated by  Andy W._dup1
