Page 3 of 3 1 2 3
#250399 03/06/02 08:16 PM
Originally posted by JVT:
Why wouldn't we have a tiny ass caliper (using the same amount of pressure as what we have now) with a 1" x 1" brake pad? Theoretically, using your logic, it would brake the same... Absolutely false...
John
No. Have you ever used a bench-top grinder? It's motor works just as much when you shove a 0.25" rod into the grinding wheel as it does when you force a huge block into the wheel with the same pressure. Yeah, the .25" rod wears down a hell of a lot quicker, but it generates the same friction at the same force. It's the same principle. While a 1x1" brake pad could theoretically stop with the same power, most of us don't want to change our brake pads every week. The modulation will also be horrible, even though the force to lock up the wheels is there.
#250400 03/07/02 04:42 AM
1
1
All your arguement was brought up by me when I was arguing with my friend. And after I got time to think about it, I found out that I was actually wrong on the part that cross-drilled rotors has less stopping power... My friend has posted anyway, so I don't really need to say more than what he had.
But the reason you can't use 1"x1" pads is because they're going to be burnt up or broken before they can slow a car down. And the reason tires are different is because they are elastic or deformable bodies. Their coefficient of drag is not constant like brake pads.
Airknight,
we've had this argument before. What you're saying is true, but I don't think it applies to rotors.
We've had this discussion before using the width of a tire. Why aren't we all running on 155mm tires? Using your logic, a 155mm wide tire will have as much grip as a 255mm wide tire. Absolutley false.
John
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
Page 3 of 3 1 2 3
Moderated by  Andy W._dup1
