Posts: 253 |
My brake parts arived direct from BAT on friday and a friend helped me install new rear pads (autozone) and the BAT Big Brake kit "C" on saturday afternoon. The rotors that arrived with this kit were EBC and are grooved and "dotted not driled to prevent rotor cracking". I did not expect these rotors as the description online and over the phone was "standard". The rotors look awesome. Does anyone else have them? what are the benefits/drawbacks to grooved rotors?
The brake install went very smooth. The brakes fit with no issues behind my 15" enkei CDR9 wheels, and my calipers appeared to be in good condition. I haven't changed the fluid in them them yet but i was careful not to mess anything up and the pedal feels firm. The brakes even initially felt much stronger than my worn out se brakes, and the more I've driven the stronger they have become. I really didn't realize that my brakes were so bad until i got these.
Bottom line, I would definitally recommend this kit to anyone looking to put SVT sized, moderately upgraded brakes on their SE. The extra money for the SVT sized brackets and rotors is well worth it in my opinion. They work fantastic and look good too.
don't drink and drive.
Posts: 477 |
got any pics?
I was considering the Big Brake Kit "A", because of the cross-drilled rotors, but shoot, if you get the gas grooved with kit "C", then I'll do that and save the dough!!!
1996 Contour SE Red V6 MTX 1995 Contour LX Champaign V6 ATX (my wife's beater) SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
Posts: 253 |
i don't have any pics yet, i'll try to borrow a digital camera from school tomorrow. like i said, i the phone they were real nonspecific as to what rotors i would get, but the ones i got are grooved.
Posts: 2,657 |
As I recall grooved rotors offer a couple advantages. One being that they provide a 'channel' for the gases to escape much like crossdrilled rotors direct the gas into the venting area. The other is they tend to keep the pads clean because the edges on the channels act like a knife scraping off crap that builds up on the pads. Those edges also give the brakes more 'bite' when you first step on the pedal because of the rough edge trying to grab the pad. Pardon all the scientific terms :rolleyes: but this is basically what I read on a site somewhere.
Posts: 3,223 |
I would love to see those rotor's.
-Andy
Posts: 253 |
Grrr!!!! Some A$$ never returned the digital camera from my commercial art class! it'll be a bit before i can get a digital camera again so i'm going to try to get a pic to scan.
BTW, The guy who runs fordmondeo.org has the same rotors on the back. they are the EBC Sportgroove rotors.
Posts: 23 |
Where did you order from? Are they all-wheel disc brakes or just the front?
Posts: 428 |
are the rotors the size of the ones on tehe svt or are they bigger??
Its a bird, its a plane...wait!..W.T.F.W.T..? #1800 of 2150
Posts: 529 |
Originally posted by 2000greensvt: are the rotors the size of the ones on tehe svt or are they bigger?? I've had the BAT "B" kit (with SS brake lines as well) installed since October. The rotors are the same size as the SVT's. I'm using the Mintex 1144 Comp pads. Stops like mad, pads are dusty as hell. It's an upgrade well worth the $400 and change I put in it.
Andrew Morris \'99 SE Zetec ATX All of life's big problems include the words "indictment" or "inoperable." Everything else is small stuff.
Posts: 1,861 |
You can also find those rotors on the Tire Rack web site.
You can also buy the caliper brackets from you friendly Ford dealer. The list price is about $85.00 each. They are the same bracket as the factory installs on SVT's an V6 Cougars.
Jim Johnson 98 SVT
