Yes on ignore ABS system. If you did try to do the ABS and got any air in it.. You would NEVER be able to purge it. The system can be flushed as said, non-ABS only and the ABS will cycle the fluid when it gets used. I try to do my fluid at least once a year. Corroded ABS parts are VERY expensive to fix. Flushing the regular brakes is a fun task!!! and I knw my ABS will stay clean and worry free.
