Posts: 128 |
Yes I searched.. anyone have the correct part numbers?
T-Red SVT E0 #2321 of 6535
Posts: 142 |
bcandiloro,
I'm pretty sure that I read in one of the posts that you need the SB1010 and SB1010S. Two of each. I think SB1010S are used in the rear because the SB1010 stuck out too far. I have a pair of each on the way so I guess I'll be finding out for sure real soon now.
George Hodge 2000 SVT Silver Frost 1188/2150 DMD HPP Rear strut tower bar SP Motorsports "22mm" sway bar BAT European Handling Kit
Posts: 82 |
I went though this several months ago..
The rears are the SB1010S, not a problem..
The Front.. (this was a little fiasco) i thought they were the SB1010.. but i have an E1 SVT so i guess the bleed screws are different??.. It turned out to be the SB8125LL. (after 3 exchanges with SB's)
Some reason they were 8mm x 1.25 and not the 10 x 1.0 The stock bleed screws that came out measured 35mm in lengh so the SB8125(L) or the (LL) should work.. the L are 32mm and the LL are like 38mm. I got the longer ones.
Make sure you look carefully, and if possible take it out and measure it.
Hope this helps
Silver 98.5 SVT 5/19/98, 6023
Posts: 3,237 |
Hope this helps Are you serious?! SH!T they are sending me SB1010 for the front. God damn it! And I have that stupid snapped bleeder in the front!
Posts: 3,237 |
I emailed "Speed Bleeder" and told them to fix their info!
FORD------------Front------Rear Contour (r/discs) SB1010 ---SB1010S Contour SVT "E0" SB1010 ---SB1010S Contour SVT "E1" SB8125LL -SB1010S
Posts: 82 |
Yup i'm serious.. 3 returns with SB (the rep at SB was p*ssed at me)  I also ordered a Ford front bleed screw from Bill J. and it is indeed 8x1.25 by 35mm lenght..
Posts: 446 |
What about the clutch bleeder, what's that part number?
Posts: 128 |
