#249490 09/24/01 05:53 PM
blake Offline OP
i didn't see anything that directly answered my question when i did a quick search, so....
i'm about to replace the pads (most likely front AND rear - rears are definitely in worse shape, though) and am hoping to get away with simply turning the rotors instead of replacing them. i have no way of knowing if they're too thin to machine until i take the car in to get the work done (i.e., i don't have a micrometer or anything). i'd do the work myself (order new pads, take the rotors to napa or someone to machine them) but time is of the essence and i don't have any to spare.
i've got 52k miles on the original pads and rotors (front and rear). neither pair have ever been turned/machined and neither pair seems to be warped (no vibration) right now.
anyone have any input as to what my chances are for a simple machining of the rotors being possible? i'm thinking of ordering a set of the mintex street pads from BAT, though my local NTB won't install pads that i provide (they installed my KDW's from the tire rack, though). i'm going to call the dealer (!!) next, but first....any input?
thanks for any comments...
blake
02 acura RSX type S, arctic blue pearl/ebony
- OEM fogs, S2k shift knob, 35% formula one tint, injen SRI
62 chevy C10 fleetside pickup, tan
- stock I-6, 3-on-the-tree, currently immobile in my garage
former owner of:
98.5 E1 SVT #4910, silver frost
#249491 09/24/01 06:07 PM
Are the rotors badly scored? If not, you could get away with not having them turned.
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
#249492 09/24/01 06:13 PM
JVT Offline
Blake,
if they've never been turned, I think you should be ok. You can always get them turned, and if they're not within spec, order new ones. You'll be ok for a few days I would think.
Trouble might be finding a shop that would be willing to turn a rotor that's under spec.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#249493 09/24/01 06:14 PM
JVT Offline
Oh, you don't have a measuring caliper? That 'could' work and give you an idea as to whether the rotors are in/under spec.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
#249494 09/25/01 01:13 PM
blake Offline OP
well, they don't appear to be scored badly, and after looking closer last night, it actually looks like i might be able to hold off on the fronts for a while. they're have a lot more pad left than the rears (which are almost gone), so maybe i'll order a set of mintex a/f street pads and tell the dealer to turn the rear rotors and install the rear pads but to just check the fronts and give me an idea of how much longer they'll last.
thanks for the replies...
blake
blake
former owner of:
#249495 09/25/01 01:42 PM
I've always ben told that the SVT rotors are built just a hair above spec, and this does not give room to machine at all. I dunno, cold be local Ford dealer lining their pockets at my expense.
#249496 09/25/01 04:55 PM
JVT Offline
I believe you are right.
I checked yesterday, and the min. spec is 22.2mm. With my caliper, my rotor is just a hair above 23mm. Mind you, these rotors have never been turned and have about 10k miles on them.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
#249497 09/25/01 05:24 PM
blake Offline OP
oooh. that doesn't sound too encouraging. maybe i best measure my rotors and see if i need to replace them too before i go order just pads...i did notice that my rears looked awfully thin....(dang it!!!)
blake
blake
former owner of:
#249498 09/25/01 08:53 PM
Actually, the rotors are pretty thick when they start life, but they are a bit soft and wear easily. On the earliest Contiques (95 and part of 96 if I recall correctly) it was not uncommon for the rotors to be worn well below minimum thickness when the pads wore out. Something was changed later that improved the rotor life but Ford never did say if it was the pads or the rotors or both. I do wish there was an easy way to know if anyone making replacement rotors uses harder material. At least they don't wear as fast as rotors on Volvos or BMWs.
Jim Johnson
98 SVT
#249499 09/25/01 10:39 PM
You may want to check for a sticking e-brake
cable. Since around 70% of braking is done with the front, you really shouldn't have
"plenty" of pad lining in front, and "gone"
rears. Considering both are of same mileage.
Something to look into.
blk.99svt
n.e.Ohio
Never under estimate the power of stupid people in large groups...
Moderated by  Andy W._dup1
