Posts: 3,237 |
Do you have to pump the clutch like the brakes to bleed it or does it drain with gravity when you crack the bleeder?
Posts: 1,022 |
you got to pump, I am sure gravity will help a little but to do a good bleed you have to pump like crazy
Micah
97 Lx 3.0 MTX lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
Posts: 852 |
I`m going to use the cheapo seringe technique. Just get a 60cc syringe at your local pharmacy (be prepared for a dirty look) and a piece of aquarium hose (clear). heat up one end of the hose and flare it on a pencil end (or similar). Slip the hose on the bleeder, and apply vacuum (you can use a piece of wood or similar to keep the syringe piston extended)Crack the bleeder, and it should bleed itself  Worked awesome on the calipers, and for a whopping 2$, you can do it yourself. I guess its even more approriate for the clutch, seeing how its hard to get the fluid out the "conventinnal" way. My 2$ canadian...
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 2,906 |
Originally posted by Micah: ...you have to pump like crazy... I did, but she got tired!
Spattmobili®
Posts: 3,223 |
If you can get underneath it is very easily accessed and you need an 8mm closed end wrench and have to push down on the rubber around it. I did it just Tuesday night. Rather easy I though.
-andy
