Patrick Offline OP
A couple weeks ago two of the four studs on my right front wheel snapped off, leaving about 1 inch inside the lugnut. I got that repaired and all is fine, but my question is: How did this happen? If it was my aftermarket wheels, I'll buy others or go back to stock wheels. Or was it excessive heat from the brakes? I'm not hard on brakes other than 1 panic stop which warped my rotors. The reason I think it was heat-related is because the surfaces of the broken studs were rainbow-hued, not rough at all. I just want to prevent this from happening again. And yes, I used search and read all the topics about hub-centric/lug-centric wheels. Can the brakes get hot enough to fatigue the studs to the point of failure?
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
N
NMC Offline
N
I had one rear wheel stud break over a year ago. I doubt the rear brakes heat up enough to fatigue anything. Just shoddy parts I think. I broke it trying to take the lugnut off. Don't remember having any trouble putting one on either. Keep them lubricated with some graphite or white grease too.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!"
87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock
http://members.shaw.ca/neilmc/
Simple answer, air impact wrenches f**k up studs!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Patrick Offline OP
Thanks, Terry, for the *concise* post. wink But these lugnuts have always been tightened by hand with a torque wrench, first to 90 ft-lbs and later backed off to 75 ft-lbs.
'98 SVT
You are taking them past the yeld point by going to 90,they have 'waisted' hence failure.take them to correct torque, run about 5 miles and re torque with the wheel & brakes COLD.Alloy wheels are like an alloy cylinder head, you NEVER retorque hot.
V6 MTX
Moderated by  Andy W._dup1
