Posts: 36 |
I am thinking about painting my calipers. If any of you have pictures of yours could you post them. I don't know what color to paint them. I have a Red 98.5 SVT. I thought about red, but didn't know if that would clash with the darker red car body I thought about black, but part of my wants them to stand out more, undecided. I also thougth about silver.
Thoughts & Pictures would be much appreciated.
d ~ 98 SVT E1 #6196 of 6535
Posts: 1,201 |
Go yellow...you will stop much faster with yellow.
If it's true that we are here to help others, then what exactly are the others here for?
Posts: 107 |
I painted mine red... they look nice. Sorry I don't pics. I have a red toreador tour and it went well. I also painted a friends silver and it looked really sweet as well. Either one I don't think you would go wrong on.
GroundZero74@aol.com 96 Zetec Contour Custom paint job, shaved door handles, touring wing, 17" white Team Dynamics Monza rims on 225/45 Nitto's, Power Stop cross drilled rotors w/ Axis pads, stainless steel braided brake lines, Eibach/Koni suspension, strut tower brace,Superchip, CTA intake, Nology wires, Nology plugs, Accel coil pack, Optima battery, NOS, high flow cat, stainless cat back w/ weapon r exhaust, Corbeau racing seats,simpson 5 point racing harness, paint highlighted interior, racing pedals, diamond plate floor mats, white face gauges, headlight strobes, under car neon kit, Pilot fog lights, PIAA driving lights,custom side markers, 20% tint all around, Fuba antenna, Kenwood mask headunit, Kenwood PS series amp, 12" Kicker Solo Baric, infinity kappas in the doors, Street Wires wiring.
Posts: 567 |
all four of mine are red, just remove the wheel, clean the caliper and spray the VHT caliper paint ($5-Pep boys) and you are done. Pic is at: http://www.geocities.com/johnh1977/svt.html 2nd pic down on left...
CURRENT RIDE: 95 GL FORMER RIDE: 99 SVT ( www.mysvt.com) "You only live once, but if you lived my life, once would be enough." -Frank Sinatra
Posts: 645 |
Did mine in black. Less flashy, buy clean and easy maintenance.
Chad ----------------- http://www.1dzine.com jetski@mindless.com 98.5 SVT ? KKM Tru Rev ? Glasspack instead of resonator ? Dyno Max Super Turbo Muffler w/Brospeed 3.5" Rolled tips ? Brembo/KVR Cross Drilled Cadnium Front Rotors and KVR Carbon Brake Pads ? Blown Engine Replaced @ 41K
Posts: 1,218 |
Sliver to match my car, anything else would be too flashy
Chow 1998 SVT #2263 of 6535 chowsvt@msn.com
Posts: 118 |
i have mine painted blue and i wish i would have chosen a color that stands out more. if i were you i would go w/ red
1995 2.0L Zetec GL ATX -KKM Intake -AR "Spyder"wheels -Tints @15% -3A Racing 85W Fog Lights -Freedom Design wing -GTS Blackouts -6 x 8 Pioneer Speakers -Ventvisors -Sony headunit -Blue Focussport wires -Flowmaster 40 Series, 2" Pipes -No Resonator -Monza 3" tip -Blue Brake Calipers
Posts: 304 |
Mad Mole Visit Mad Moles Mondeo Madness 2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc. 192 BHP, Faster than a speeding Duratec!
Posts: 1,070 |
are you able to just mask off everything then spray the caliper? are there any parts of the caliper that i should make sure i dont get paint on or in?
i want to do this but worried about messing something up.
Proud former owner of..... '99 svt - silver/blue - #2555 of 2760
Proud new owner of... '02 BMW 330i
Posts: 107 |
Yeah just mask everything you don't want painted. Make sure the piston is masked off. If your scared of spraying.. Use the brush on lacquer. Folia Tec puts it out. You will get less fade and corrosion with the lacquer as well. I used both the spray and lacquer and find that the lacquer looks nicer. More glossy.
