Posts: 4 |
Speaking of brake fluid, is there any special reason spec for the 1998 SVT calls for DOT 3? The DOT 3 requirement doen't seem to make sense.
Posts: 323 |
Like I need MORE clamping force on my already warped rotors??? Piece of crap OEM brakes...
'98 SVT KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
Posts: 3,223 |
The higher the D.O.T. level the more frequently you have to change the fluid because it sucks up more moisture faster than the lower D.O.T. level.
DOT 3 last longer but has a lower boiling point. DOT 5 absorbs more water faster but has a higher boiling point. Most street cars won't hit the boiling point unless you are Autocrossing or pushing it big time to get it up into those temperatures.
-Andy
Posts: 1,202 |
Ummmm ... with all this knowledge flying around I now know I need to change my break fluid. Of course I have the Baer Kit and love stomping them all the time  Comes with the braided lines which I like but with the bigger brakes I didn't really notice a gain. The things just stop the car, pretty much no matter what is thrown at it.
Married the gal of my dreams 04.27.02  2K SVT Black/Midnight Blue #294 of 2150 DOB 10.29.99 kbucy@fbr.com ktigerj on aim A *few* Mods Best Time 14.942 at 93.98mph Car is now for sale - 14000
Posts: 852 |
Hey Chow, know any DOT approved stainless steel lines? Cause I don't...
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 416 |
Originally posted by mangler: Hey Chow, know any DOT approved stainless steel lines? Cause I don't... SP Motorsports claims the Areoquip's to be. http://www.spmotorsports.com/contour_brakelines.html
Posts: 852 |
And yet aeroquip claims their lines are not... :rolleyes:
Posts: 38 |
Earl's Teflon/braided stainless STEEL BRAKE lines are DOT approved. http://www.earlsperformance.com/html/index.htm I'd be surprised if Aeroquip Teflon/Stainless lines were not DOT approved, as they are pretty much the pioneer of braided SS hose, although primarily for the aircraft industry. Make sure you only use the braided SS hose w/ Teflon liner for brake lines as the rubber lined is not suitable for brakes. But great for fuel lines tho. jay
jay bass deltaman@mindspring.com jb@thedelta.com '99 SVT Contour (tropic green/tan) 557 of 2760
Posts: 852 |
Yes, I read the Earl lines were DOT approved. Is there an application for the contour?
I was surprised also... http://fp.enter.net/~suncoast/Brake%20lines.htm
Posts: 38 |
Actually, I believe Earl's only available thru retailers, primarily speed shops. And i don't believe they market their hoses pre-assembled for specific applications. I'm not current on their offerings, but back in the '80s when i had a speed-shop business i carried the Earl's line & I had to order the hose & components, then custom cut & assembly the hose @ my shop to suit customer reqmts. Brake lines were an exception, in that pre-assembled hoses were ordered pre-assembled (and I believe pressure-tested), for safety sake. But the hose was ordered by size (AN-4 for brake lines) & length provided by customer. Some specialty shops, such as for Corvettes, for which I have knowledge of, offer application specific brake lines based on their own measurements. You may find similar offerings for Ford autos. If i recall, the best hose to use for brake lines are those w/ crimped-ends (vs. the reusable ends) & also w/ short-stiff plastic sleeves installed over the hose at each end. I strongly suggest regular examination of SS/braided brake lines for fraying or leaks, which generally occur @ ends. Hope this helps. jay
