Page 1 of 3 1 2 3
#249047 07/06/01 07:07 PM
Been reading a few posts that suggest installing steel brake lines in the front. Do they wear better? Handle the heat better? Why?
Ryan W.
1998 T-Red SVT E0 #634 (KKM, A6 Side Markers, +more)
CEG Registry - Austin/Cedar Park, Texas
ryanwood94 on AOL Instant Messenger
"Why steal brake lines....."
Its cheaper than buying them.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Supposedly the reason for the "steel" brake lines is that under high pressure (ie panic stop or heavy braking) the rubber lines will expand causing you to lose some hydraulic pressure. The steel lines won't expand and therefore the hydraulic pressure from the master cylinder is completely transferred to the calipers. Or something like that smile
Deron
'99 Tropic Green SVT #924/2760
K&N, Mobil1, '98 Clock, dual horns,
SHO Shop Rear Strut Tower Brace,
BAT Rear Sway Bar Bushings,
ST200 Shift knob, Pioneer TS-A6855
ARGH! smile I guess I should proof read my messages before sending them.... smile Sorry, "Steel" was intended.... smile
Ryan W.
jk, couldnt resist.
how hard are they to install?
About the hardest thing about steel braided lines is paying for them. Installation is very straight forward. Many report good improvements in braking response and feel. Remember to throughly flush/bleed the fluid afterwards.
Dave
'98.5 SE V6 Mtx
'00 Civic Si
Administrator
Administrator
another benefit of stainless steel brake lines is improved resistance to heat. In a track or autoX type environment, heavy brake use creates tremendous heat, which can soften rubber brake lines and in a few cases (not on Contours) hve caused stock lines to fail, resulting in a failure of the brake system.
W/ Stainless steel braided brake lines, you are basically buying peace of mind, which is always a good idea, and they look cool too laugh
It's all about balance.
bcphillips@peoplepc.com
oh ya make sure there D.O.T
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
Originally posted by Rara:
another benefit of stainless steel brake hve caused stock lines to fail, resulting in a failure of the brake system.
Oh I'm sure that would be real nice while you are speeding around a parking lot, with lots of spectators watching wink
This is from GrassrootsMotorSports-Brakes
Brake Fluid
While you're focusing on brake pads, don't forget to check out your brake fluid. If you can't remember the last time you changed your brake fluid, do so now. Brake fluid absorbs moisture over time, which causes a large number of problems, including spongy brake feel, rusting components, etc.-none of which you really want to deal with. Speaking of brake fluid, remember to bleed it often at an event, especially if you're racing in a humid climate. Your brake fluid is expected to work under some incredibly hot situations. In many cases, this is also a weak spot in the system.
When buying fluid, remember that the higher the rating, the better the stuff. DOT 4 fluid is better than DOT 3, and DOT 5 is better than DOT 4. However, beware of silicone-based DOT 5 fluid-it can give you a mushy pedal. Go with glycol-based DOT 5.1.
Brake Lines
When you stomp on your brake pedal, the fluid not only pushes through the brake lines, it also pushes against the brake lines, causing inefficiency in the system. How can you combat this loss? Replace the stock rubber brake hoses with braided stainless-steel lines. The swap is fairly easy and inexpensive. Expect a firmer pedal when done. Check your rulebook before making this mod; also, not all stainless lines are DOT-legal.
Enjoy, and don't get caught stealing brake lines wink
STD's are like Pokemon...
Gotta catch em' all!
Page 1 of 3 1 2 3
Moderated by  Andy W._dup1
