E
E
Can you paint your front brake calibers with out removing them? I really don't fell like clamping off and bleeding the brakes.
1995 2.0L Zetec GL ATX
-KKM Intake -AR "Spyder"wheels -Tints @15% -3A Racing 85W Fog Lights -Freedom Design wing -GTS Blackouts -6 x 8 Pioneer Speakers -Ventvisors -Sony headunit -Blue Focussport wires -Flowmaster 40 Series, 2" Pipes -No Resonator -Monza 3" tip -Blue Brake Calipers
It can be done, but by the time you clean and mask with the calipers in place you may wish that you would have just removed them anyway. It is just not that hard of a job to bleed the brakes. Many have done what they think is an acceptable job without removing them, while others have reported that they did not obtain an accptable job working around the rotors and pads.
If you do decide to paint them in place, clean them up carefully with brake clean spray and a small wire brush (the size of a tooth brush). Mask off the stuff you don't want painted with rags, paper towels, newspaper, and/or masking tape. Make sure that you sue paint that is up to the task. It should be at least hi temp paint and preferably brake caliper paint.
Jim Johnson
98 SVT
I just sprayed the paint into a small container and brushed it on. No masking necessary and you get better control. Possibly a bit faster. But does not go on as heavily and you need to clean the brush frequently. Make sure you clean your calipers well before painting. Look at my pics (in sig) for results.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
I did the same as THECONTOURGUY about four months ago. I cleaned the calipers with alcohol and a wire brush. I used high temp spray paint, I just sprayed it into the can's cap and used a brush. Yes, I had to clean the brush often. But the paint is so thin, It is starting to chip off.
USE SOMETHING THICKER THAN SPRAYPAINT!!! wink
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
JSmith -- I used high-temp brake caliper paint. It is not flaking off after nearly 6 months. What type of paint did you use?
Dan Parmelee
I painted all four of my calipers without removing them. Just follow what BigJim suggested and mask everything off. I used brake cleaner to clean everything off. Make sure you get ALL of the brake dust off before you do this. I used high temp paint from PEP BOYS. I think they look great. Obviously if you dont take them off it's hard or impossible to get all the way around the calipers but who's gonna see the backside. If you were doing this for a show car you wouldnt have asked if you need to take them off. Leave 'em on. It's 20min's versus 2 hours. And if you buy spray paint, spray it, that's what it is designed for unless you are really handy with a paint brush it will go on smoother and look neater if you spray it. Good luck.
99 SVT running 10/10ths 9/10ths of the time. Member SVTOA!
Tropic Green, KKM Pedal Covers, K&N filter, Red Brake Calipers, PaceSetter Monza Resonator Tips, SHOshop rear strut brace, new AC compressor at 11k mi (brrrr), door guards removed, Nitto 450's.
Excuse me waitress, what's the soup du'jour?
It's the soup of the day.
Mmmm, that sounds good. I'll have that.
its a brake caliPer not a caliber!! Man that drives me nuts!!
Ryan
98.5 Silver Frost Tour SVT 5979/6535
Born: May 15, 1998
Some Mods, still not fast enough..
90 Black SHO
SVT Performance.Com
Done this one as well. Tape everything up (especially all the rubber hoses, caps, etc.), and grab some caliper paint (VHT is a good brand found at auto stores, jcwhitney.com, etc.) The main thing to remember is to tape some old bedsheets to the ENTIRE side of your quarter panel, doors, hood, top and trunk. A light wind and overspray can carry a long ways...
For best results, make sure you do it when it's hot outside and put around 5-6 coats on the calipers. Paint one coat, wait about 20 minutes, then paint another coat. It really gives you a nice, deep glossy look on your calipers, and one that you won't have to touch up for quite some time.
Good luck.
JaTo
Overland Park, KS
JaTo@kc.rr.com
99 Contour SVT
#143/2760
Modded to Taste
00 Corvette Coupe
Modded to Haste
I painted mine just like JaTo did. It came out nice.
[img]http://albums.photopoint.com/j/View?u=1719576&a=13217629&p=51217124&Sequence=0&res=high[/img]
Ray G.
99 SVT
KKM intake
e-ram
B&M short shifter
ASP pulley
SHO shop y-pipe
Borla exhaust
Mintex brake pads
KVR Cross Drilled Rotors
Steel brake line
Koni Adjustable Struts
Eibach Pro Kit Springs
MSDS Headers
Moderated by  Andy W._dup1
