Posts: 852 |
I believe this is common knowledge by now, but let me rant a bit, if you will.
My rotors are beyond repair at 45K miles. They have rotted, spalled, and pieces have broken off the outside edge (from rust). I thought the guy was full of BS when he told me he could not turn them, but it was true. They would not have met minimum thickness for sure, and the heat cycling had formed cementite (look for it, its like gold colored zones, often near the hub). Cementite is a form of carbide, which does not machine very well.
I would expect a horror show if i was hard on the brakes. But I mostly do highway. So, either the rotors are too small, or the Ford rotors are the cheapest thing on the face of the earth. At almost 100$ us a pop, I would expect better. Anyway, all the corrosion I have seen inside the vented part warrants plating my next rotors.
rant out.
------------------ Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 185 |
Originally posted by mangler: My rotors are beyond repair at 45K miles.
Mine were warped at 32K and I don't race or autocross at all. Got a brake kit from SPmotorsports on the way. Chris 99 SE V6 5sp
Posts: 109 |
You are lucky that you got 45k out of your rotors. Mine were replaced alongwith pads at 30k service, and the car mostly had highway miles. The mechanic that I talked to said that that could turn them, but decided not to bother. Since ford picked up the tab, I did not object.
-Aleksey 98 LX practically stock
Posts: 5,805 |
On any 'vented rotors',stock or aftermarket,its a good plan to paint the inside of the vents with say Sperex VHT,it reduces rust and improves the life,the better cooling also helps. ------------------ V6 MTX 'Buy the tools and dodge the fools..." 'Its only nuts & bolts!' Terry's Website
Posts: 1,861 |
Arn't you happy that it's not a Volvo or a BMW? Rotors are typically worn out by 45,000 miles, but by then you have replaced the brake pads two or three times (without machining the rotors). Let's remember that these are actually european cars and as such still have a few european traits, among them, the tendency to wear out rotors. At least the brake pads don't need to be replaced every 15,000 to 20,000 miles. I agree that this is not really acceptable by US standards, but it could be worse. Jim Johnson 98 SVT Originally posted by mangler: I believe this is common knowledge by now, but let me rant a bit, if you will.
rant out.
Jim Johnson 98 SVT
Posts: 65 |
Jim,
Are you sure that our rotors are European spec? I thought only the SVTs get the Euro-sized rotors, and then only in the front. But I agree that about 50K miles is a decent lifetime for rotors.
-- Barry Wolf 1996 Contour SE MTX Midnight Red, Parchment leather Brakes: Bendix OEM size discs, Carbon Metallic Pads, Parking Brake TSB kit Engine: New IAC valve, new EGR valve, new cat, new water pump, moose fix kit, K&N drop in filter Tranny: Redline ATF + Ford Friction modifier Interior: Pioneer CD receiver, Pioneer speakers, Ford RS shift knob, Ford vinyl floor mats (great purchase!) Handling: E1 SVT Rims, Yoko AVS-I 205/55ZR16 (like butter) meats Other: High beam bulbs in low beam position, new trunk vent Other problems: leaky PS pump - fixed with 2 oz stop leak, 1 quart oil use per 2K miles Mileage: 62K (August 2002)
Posts: 1,969 |
I think he is referring more to the design of the caliper which utilizes a single slide pin design which is found on a lot of european cars...
------------------ Atlanta, GA 1999 Silver Frost 2.0 SE Zetec K&N Filtercharger Mintex Street Pads BAT Rotors Sony ES Mobile Xplod Pioneer 3-way 6X8's all around BAT Bright Whites Fog light re-content Painted Grill and Interior Accents
Kharma is very real and she is one mean b!tch.
Posts: 852 |
I suppose it must depend on the specific model and usage. My father went 120000 miles on his stock rear BMW 528 rotors. Granted, it was not driven hard, but it was an automatic.
Posts: 1,861 |
Basically I'm refering to the entire car as european, not specificall the brake rotors. When the Contour was first introduced it became common knowledge that the rotors needed to be replaced when the pads wore out, but things improved (I think part way through the 96 production). Ford claimed to have improved the materials for better rotor life with new part numbers for both the rotors and pads. It did help in that the newer ones seem to have a bit less rotor wear and longer pad life. My 98 E0 SVT still has the original front brakes at 100,000 miles and it looks like they still have a lot of pad remaining. I miked the rotors when I replaced the tires a few weeks ago. They are close to minimum thickness so they will need replacing when the pads wear out. They were machined once under warranty at about 18,000 miles due to warpage. There is a very pronounced lip on the outside edge, what Volvo referred to as "dish" as in the edge of a dish. Showing that the rotors have worn much since they were machined. Just for reference though, a 100,000 miles on Contour brakes would be about like 30,000 miles on a Volvo. Jim Johnson 98 SVT Originally posted by barrywolf: Jim,
Jim Johnson 98 SVT
Posts: 65 |
Wow! 100K, in my opinion, is phenomenal for front rotors. I think it does help that you've got an SVT with more massive rotors up front.
The rotors on my Tour (front and back) warped at 40K and since the cost of turning them was equal to new rotors, I threw the OEMs in the trash. The new OEM sized Bendix rotors have been great so far, but I've only put 6K miles on them, so I really can't draw any conclusions about their construction.
------------------ 96 Contour SE
