Page 2 of 3 1 2 3
#248263 03/18/01 12:31 AM
4
4
My rotors were junk at 43,000 miles. They were so rusted to the hub that I had to use a very big hammer to pound them off, destroying them in the process.
'98.5 Mystique GS ATX/re-contented door lights/K&N Filter/Energy Suspension Sway Bar Bushings/Mintex Street Pads/high-beam bulbs in low-beams/Pioneer DEH-P3100 receiver/Pioneer TS-A6855's in all doors
Justin
'02 Ranger Edge ext cab
Retired: 98.5 Mystique
#248264 03/18/01 11:52 PM
Try using a good penetrating oil and some heat next time. If you have the chance, you can shoot it a few hours in advance with a good oil (my dad gets this 'Aero-Kroil' stuff from work, which blows circles around WD40.
The oil and a rubber mallet should do the trick...
Andrew
99 SVT
Andrew
99 SVT
#248265 03/19/01 05:18 AM
When you put the rotors back on, always apply a bit of anti sieze between the hub and the rotor including at the center where the rotor fits over the bearing so that it will be easier to remove next time.
Jim Johnson
98 SVT
Jim Johnson
98 SVT
#248266 03/20/01 01:45 AM
4
4
I was using penetrant. Thats how stuck those things were. They had never been removed from the car. I have seen several other Contours and Mystiques at work with the same problem. I used anti-sieze and the right front rotor came off easily on Saturday when I had to replace the wheel bearing.
Justin
#248267 03/20/01 01:57 AM
You should get a brand new set after dip them in liquid nitrogen to make less space available between the molecules of the composite metal the brakes are made from. Then get a hammer and forge them to make them thinner, you'll see they will shine a little when they're thin enough.
Tour 1999 pro SVT LTD
#248268 03/20/01 11:03 AM
Huh?
Tony Boner
#248269 03/21/01 01:16 AM
mangler Offline OP
This guy is on medication. His budget is a little short this month, so i guess he has to cut back...
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
#248270 03/25/01 10:11 PM
mangler Offline OP
I'm sorry, but for 144$ canadian, they are gonna keep their OEM rotors. Somehow, I put much more trust in Brembo or even Raybestos, and their rotors are priced at 70$.
Marco Tatta
EGR block, fog light fix, custom shift boot
Marco Tatta
#248271 03/28/01 01:19 PM
Well I just put $29 dollar rotors on! My pads were $19. dollars. Lets see how these ultra cheap rotors and pads compare to Fords! So far no noise and brakes nice! Well see if being cheap is smart or if I got what I paid for (crap) Well see!!!!!
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#248272 03/28/01 02:57 PM
N
NMC Offline
N
I think it's total luck whether you get good rotors or bad with the cheap stuff. I put good stuff on my car and they warped. I put cheap stuff on my girlfriends Escort and they didn't(and she drives like a maniac). My Explorer was perfect for 135,000 km, and all I did is change the pads. The stock rotors in my Celebrity warped, their cheapo Canadian Tire replacements lasted 50,000 km till I sold it.
I'm looking for Brembo's this time cause my friend says they are the supplier for Audi. He has an A4 and as hard as he drives they are perfect too.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!"
87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock
http://members.shaw.ca/neilmc/
Page 2 of 3 1 2 3
Moderated by  Andy W._dup1
