Page 2 of 2 1 2
I just put my gas slotted Brembo's on two weeks ago and took photos. I'll post those ASAP. I used a 7mm socket Allen wrench on the locating pins (2) for the front calipars. Chilton's was wrong. They advised the use of a T40 Torx which didn't fit. The rear locating pin needed a T55 Torx. I used a huge 6 inch C-Clamp to compress the front caliper to put the new pads on. Do it with the old pad on the inside before you remove it. The rear caliper needed a universal rotating caliper piston tool. Autozone had all the tools for under $20.
Modifications:
H&R Springs
Koni Adjustable Sport Shocks
Brembo Slotted Rotors
KVR Performance Carbon Fiber Pads
Wilwood 570 Brake Fluid
Potenza RE 71 Tires
KKM Air Intake
Bosch Plus 4 Spark Plugs
Cat Back 2.25 Exhaust
No Resonator
Dynomax Muffler
DON'T FORGET! ***
Make sure you put anti-seize compound on the hub/rotor assembly when you put it back together, then you shouldn't need that rubber mallet Paul was talking about the next time!
Don't you think that the auto manufacturers, knowing that there is anti-seizing compound available, would put *just a few drops* of the stuff on the hubs BEFORE they assembled our vehicles ??? DOH! Is it TOO easy, or what ?!?
Pete...
1998 SE Sport ATX
Black Clearcoat on Greystone
62k miles
K&N Drop In
Pioneer Premier KEH-P690 w/TS-A6815 3way in each door
Transmission Failure 31k miles
A/C Compressor failure 37k miles
"SB LIVE" Plate
Pete...
98.5 SE Sport Duratec ATX (P66L)
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Page 2 of 2 1 2
Moderated by  Andy W._dup1
