Page 2 of 2 1 2
#245388 06/03/02 05:34 PM
Well, biggest difference is the bottom end. 1G's have a 6 bolt bottom end, and 2G's have a 7 bolt. Those are the crankwalkers.
Exact same 4G63 motor though.
2G's havr a t25 on them, where as 1g's have a 14b. t25 = garbage.
1G is claimed to be 195hp and 2G 210hp.
You will regret a 2G. Trust me.
1991 GVR4
Lots of mods done.
#245389 06/03/02 07:34 PM
F
F
geez...so how much would a decent 1G cost..and labor.. I would have to buy an older 2G body and a good 1G motor.. then installation into the 2G body style:( Ok 3L your still lookin good.
And you will spank the hell out of any 3L contour.
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
#245390 06/03/02 07:55 PM
You can do it all yourself and save the labor on it. Buy an older 2g if you like the body of them. You can get em for about 2-4K depending on shape. If it has no block, prolly will be cheap as shiit. like 1500 - 3K
You will have no more than 5k in it.
1991 GVR4
Lots of mods done.
#245391 06/03/02 09:23 PM
I am by no means an expert on Mitsu motors....but our very own Contours suffer from the very same problem of "crankwalk". All 2.5L Duratecs have the same problems. This "crankwalk" is believed to be the cause of the actual oil starvation issue. The "crankwalk" causes the bearings to shave and block the holes where oil would normally enter the chamber....thus increasing friction and frying your engines crank. The solution the Ford has finally chosen to implement is the Dual Mode Dampner. The DMD is now standard on all 2.5 Duratecs over in Europe.
Is there a DMD available for the Mitsu?
Why does the first generation engine not suffer from "crankwalk" where the 2G does if they are the same?? Strange.
Now...the car you are looking at has only 20K on it...that is very, very low.
I'd say go for it. GSX's are pretty rare....I've only seen 2 around town....EVER!!!!
Good luck!
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile
Moderator of the Florida Contour Enthusiast Group
#245392 06/04/02 03:18 AM
GSX's are a dime a dozen here.
The 1G's have a 6 bolt bottm end, where as the 2G has a 7 bolt. There lies your differnece. The oil squirters on the 7 bolt bottem end do not exist. There lies your trouble. DMD will do no good.
1991 GVR4
Lots of mods done.
#245393 06/04/02 03:51 AM
I owned a 1g or actually i still own a 1g, mine suffered crankwalk or actually the thrust bearing went out and my crank would go in and out of the block. Definately would go 1st gen motor of 2g motor any day, 2g= garbage. Some other considering which I did w/ a friends car is we got the evo iii motor and it bolted up and from the factory it has 270hp. Definately could tell the diff. Only prob was that the intake man. would not fit b/c of the ac and the motor that he got was out of an automatic and that obviously means it had the crappy turbo(tiny). So we swapped his factory 14b and put it on. Runs great. Got the motor in Ft Myers I believe and it was about 1200. Btw, the owners have a real right hand drive lancer and a true silvia.
'00 svt #1485/2150
KKM, Borla, Fog Mod, B&M, Intrax Springs, TH Fix
http://www.imagestation.com/album/?id=4291647931
pass: ceg
Soon: MSDS Headers and Y-pipe, BAT 22mm Sway, DMD, and Koni's
#245394 06/04/02 04:40 PM
Ahhh...I see what you are saying now. I learned something new today!! laugh
Of course you see a ton of GSX's. Down here in SoFla I've only seen 2...ever!!! confused
Page 2 of 2 1 2
Moderated by  Lee_dup2, unisys12
