Posts: 19 |
Neither one of my contour motors used oil. Spun bearings but used NO oil.
Eric 99 Maxima SE, MTX, Apexi WS, Clear Corners, Short Ram Intake, Red/Clear Tails
95 Contour SE, MTX, SVT Duals, S&B Intake.....2nd motor...1st Rebuild
Posts: 62 |
I use no oil between changes with Mobil 1 5-30. I have 72,000 miles.
96 Black SE 2.5L V6 ATX
Posts: 770 |
Originally posted by louisw: Mine uses about a half quart between changes (6 mo./5-7k miles). There's been a small oil run down the filter, even though it's tight every time. Oh well... Make sure it is not too tight - that will warp the rubber gasket...!
Andrew 99 SVT
Posts: 1,244 |
I couldn't tell ya how much oil my Zetec uses. I let the dealership handle it, because if they break something they fix it. Also I am paying $12.95 an oil change for letting them do it.
Posts: 7,329 |
Originally posted by Terry Haines: I'd let it go in the engine Demon...you could calaim the first '2-stroke' SVT..!!!!!!! heheh... :p
Posts: 816 |
I don't consume oil, the doctor said it'll hurt my tummy.  My zetec don't use no oil though. In fact it's above full righ now. It might start using some when i make the switch to synthetic.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 3,223 |
Originally posted by Redcon96I4: ... My zetec don't use no oil though. ......... That means it does use oil! LOL! -Andy
Posts: 1,701 |
Amazingly enough, my old beater is still using basically no oil. It has developed a small drip (1 drop/night) but this ends up being maybe 1/2 Qt. over 3000 miles.
