Posts: 17 |
Hello all,
I just recently lived through a partial engine-rebuild job and I'm very curious, what your oil consumption is like.
I'm using Mobil 1 5W-30, always overfill half a quart, and my engine uses 1 quart per 1000 miles.
E0 SVT, Toreador red
Custom true-dual cat-back exhaust SHO-shop off-road Y-pipe SHO-shop cold air induction
Posts: 55 |
My 98 Mondeo V6 ATX (170 Hp Duratec) with 44000 mls on it did not require any additional oil between the 9500mls (15000km) service intervals. It went from full to well abow low on the dipstick in that distance.
My current 2002 Mondeo with same engine seems to use more. But I do a lot of Autobahn driving now, and I keep it a lot above 5000 RPM. I had to top off 1 quart after 10000 km (car has 14000 km on it now). But this may be due to the initial breaking in phase, I don't know what it will be in the long run.
Joerg
Posts: 3,950 |
My car never needs extra oil.  Only during oil changes.
Posts: 182 |
I'm using Mobil 1 5W-30, always overfill half a quart, and my engine uses 1 quart per 1000 miles. That useage definitely seems excessive to me. My 98 SVT doesn't use a drop.
Chad Purser '98 Silver SVT Mostly Stock
Posts: 587 |
Originally posted by cpurser: That useage definitely seems excessive to me. My 98 SVT doesn't use a drop. Hear, Hear! Ray
Posts: 332 |
Black E1
Posts: 1,770 |
My dipstick doesn't show any usage between changes (5K mi.)
Posts: 153 |
I read in an article somewhere that there was not a single warranty service for oil usage in the Contours in like the first two years of it being out there. They were pretty darn proud of it. If your's is using that mucch (vs it leaking somewhere?) I would guess something is definetly amiss with your rebuild.
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's 154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats. My Profile
Posts: 532 |
No noticeable change in dipstick level after 6K miles using Mobil 1 Komrad!
Dan B.
Posts: 223 |
77,000 miles and I've never had to add oil. Not a drop on the garage floor either (knock on wood).
Black '98 SVT KKM Intake 17" Enkei's SS Y-Pipe 9mm Ford Racing plug wires Various aesthetic mods.
