Posts: 87 |
Yo Gator, do you know the parts numbers for the parts??? UI, LI, EGR, TB, and the other one(s) I might need?
99 Silver SE Sport V6 MTX
Posts: 4,319 |
Originally posted by C0NT0UR: Yo Gator, do you know the parts numbers for the parts??? UI, LI, EGR, TB, and the other one(s) I might need? d00d, you are killing me! READ THE FAQ!! :p :p :p Upper intake manifold gasket P/N F5RZ-9H486-B (1 set) Injector nose O-rings F0PZ-9229-A (pkg of 10) Upper injector O-rings F5RZ-9229-AB (comes in a pkg of 6, but you are charged for each) Lower intake manifold gasket F5RZ-9439-B (1 set) Throttle body gasket F5DZ-9E936-AE EGR gasket E6AZ-9D476-B IAC gasket E83Z-9F670-A
1991 GVR4 Lots of mods done.
Posts: 1,619 |
Originally posted by Gator VR4: Originally posted by C0NT0UR: [b]I told them that a mechanic that specializes on my car looked at it Hands down the funniest thing I have ever heard! I am still recovering from the laughing fit I just threw![/b]So Neil......you don't think I know more about the Contour/Mystique than 90% of the Ford Technicians? I think I qualify as a mechanic that specializes on Contours...don't you?  :p
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile Moderator of the Florida Contour Enthusiast Group
Posts: 87 |
Hey, I ran my car this Friday and my best time (Which was my best, cleanest run ever in my opinion) was a 15.8!!! I can't believe that sh..! I'm going to buy those gaskets this Tuesday! I've had enough with my slow car! Ryan, when do you think we can get together and clean up the manifolds, TH fix, TB optimization, and any other cheap mod you know of that'll help me out performancewise? Thanks a ton!
Posts: 715 |
Originally posted by C0NT0UR: Hey, I ran my car this Friday and my best time (Which was my best, cleanest run ever in my opinion) was a 15.8!!! I can't believe that sh..! I'm going to buy those gaskets this Tuesday! I've had enough with my slow car! Ryan, when do you think we can get together and clean up the manifolds, TH fix, TB optimization, and any other cheap mod you know of that'll help me out performancewise? Thanks a ton! What is your best time...it says 15.6 in your signature
Jim NY Mets World Champions in 2002 2000 Black Contour SVT #53 of 2150 17" Konig Traffic w/Nitto 450 Borla Cat Back Zaino MB Quart and Shiva
Posts: 4,319 |
Also, what kida of times are you hoping for? 15.56 is a very respectable time for your car. I doubt cleaning the secondaries are gonna net you more than a tenth or so...If you want faster times, get N20....
Posts: 1,619 |
Originally posted by C0NT0UR: Hey, I ran my car this Friday and my best time (Which was my best, cleanest run ever in my opinion) was a 15.8!!! I can't believe that sh..! I'm going to buy those gaskets this Tuesday! I've had enough with my slow car! Ryan, when do you think we can get together and clean up the manifolds, TH fix, TB optimization, and any other cheap mod you know of that'll help me out performancewise? Thanks a ton! Sure...we can do that...but not this weekend........I'm busy alllllllllll weekend. Maybe the following weekend!!!
Posts: 87 |
Well, the thing is that my manifolds have a TON of crap in them.. Ask Ryan, there is a lot of oil buildup in them.. I don't even squeal while going into 3rd anymore!!! Trust me... I'll make a LOT of a difference!!!
Posts: 87 |
Mets SVT, what I meant was that the shifting was so smooth and perfect, that if I were to have my car before I had my accident, I swear I would have ran like a 15.3! With my fastest run (15.56) I wheel-hopped through 1st... I started off at 2500RPM.. I now know that 2K RPM is the best time for me to release the clutch... Once again, turst me when I say that when I clean my 2ndaries it'll be a lot faster than now.
Posts: 1,619 |
Originally posted by C0NT0UR: Mets SVT, what I meant was that the shifting was so smooth and perfect, that if I were to have my car before I had my accident, I swear I would have ran like a 15.3! With my fastest run (15.56) I wheel-hopped through 1st... I started off at 2500RPM.. I now know that 2K RPM is the best time for me to release the clutch... Once again, turst me when I say that when I clean my 2ndaries it'll be a lot faster than now. You got yourself a ringer!!! I don't think anyone in a regular V6 (stock) has ever run faster than what you have. With all my mods plus a new clutch (and new fuel injection wires) I'll be lucky to click a 15.4
