Posts: 1,619 |
Originally posted by Micah: answer the questions for you? Micah Yes...yes you did. But.......if I put my 2.5 heads on there, what kind of power should I expect? 210-200 HP...the same for torque? I've been reading a lot in the 3.0L forum but I'm still a little sketchy. I really want to do this. I get my bonus in Feb and a raise in March.....aww yeah! To me...upgrading to 200lb/ft of torque should show some impressive gains to 60...no?
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile Moderator of the Florida Contour Enthusiast Group
Posts: 1,022 |
Just droping the 3.0 in will be a nice gain for a non svt. 30 more horse. tons of more torque. I dont know how hard or anything it will be for your car, sence you have a 95 (OBD I)you will have to see if that is possible. as long as it is, there will be no probs. I cant get you number of torque or hp on a non-svt 3.0 swap. I havent dynoed my car yet, I have had people say I wont hit the 200 mark on both hp and torque (at the wheels.) and I have had people say I will. I think I will be right around 210hp and 200torque, thats due to the fact of all the mods I have.
List: kkm intake lighten flywheel UDP pulleys no Main Cat True Dual Exhaust No res Egr Block 75mm MAF bored upper intake svt throttle body 24lb injectors
I think that will get me the 210 mark easily with some good tunning, once I get the S-AFC.
Micah
97 Lx 3.0 MTX lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
Posts: 1,619 |
Originally posted by Micah: I think I will be right around 210hp and 200torque, thats due to the fact of all the mods I have. List: kkm intake lighten flywheel UDP pulleys no Main Cat True Dual Exhaust No res Egr Block 75mm MAF bored upper intake svt throttle body 24lb injectors I think that will get me the 210 mark easily with some good tunning, once I get the S-AFC.
When you say 200, I assume you mean 200hp at the wheels, which is more like 230 hp, correct? If so, that is a very nice gain. I'm not sure how the 95 electronics will affect me swapping. I think I may have to ask Terry Haines about it.
Posts: 583 |
I will be doing the 3.0 after the brullen and apexi. I will be using the 3.0 block with the 2.5 heads.. Question though..with the high compression..how safe will nitrous be?
Thanks Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 1,022 |
it wont be, There is no chance of you keeping that engine with the 3.0 block and 2.5 heads. no NOS, turbo or s/c will go on that setup, unless you want to blow the engine. like I said a few replys back. the 2.5 heads on the 3.0 is for people that want alot of gain and staying N/A. if you want to put NOS,Turbo,S/C. do the whole 3.0 swap with the 3.0 heads.
Micah
Posts: 583 |
Micah, did you say you have the 2.5 heads with the 3.0? Although I might want nitrous in the future I will go with the 2.5 setup and avoid it.
Thanks for the info, Eric
Posts: 1,022 |
Hey, Yea I have the 2.5 heads on my engine. was thinking of putting the 3.0 heads on to get a turbo in there. But i think i am going to stay with the 2.5 heads. this setup will let you run a low 14 high 13 sec car in the 1/4 if you want more do the 3.0 heads with NOS or a turbo Micah
Posts: 583 |
I think with a daily driven car low 14 high 13's are fine for me.. Plus with all the tinkering people do I'm sure someone will come out with better performance numbers somehow someway. There are all motor 12, 11 cars out there.. Eric
Posts: 4,319 |
Yeah, keep your current engine and throw some NOS on it. You'll hit low 14's all day..........
1991 GVR4 Lots of mods done.
Posts: 1,022 |
Yea, but thoughs 12 and 11 sec cars are not front wheel drive  I think the best we could do N/a with the 3.0 would be mid 13 or low 13 with slicks. you trying to make a drag racer or a daily driver? N/A will be fast enough for a daily driver, I think, But what do I know I still want the turbo Micah
