Originally posted by T-RedSVT:
OK, Mike has the fuse numbers for the turns, but sounds wierd that the prking lights worked. Miget be a turn signal relay. Do you hear the "tick-tock" sound when you put the turn on, or does it just stay illuminated...?
No, everything works as usual, only difference is that the passengers side parking light (low light of amber bulb) does not work. The blinker (high light of amber bulb) on both sides work just fine. Thanks, i'll try replacing the fuses first.
