#24286 07/14/02 06:59 PM
mbb41 Offline OP
I think from searching that the pronounced rattling nosie I've had under acceleration may be from pinging. Since I've lost power I'm wondering what the long term effects of pinging would be?
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
#24287 07/14/02 07:09 PM
E
E
mbb41,
If you are accelerating from a low speed / low RPM point, the rattle is most likely coming from the MTX. That type rattle is normal and is a "sign" for you to downshift or backoff a little on the gas. I do not accelerate "firmly" at anything under 2500RPM. If this is not your senario...nevermind...
...Ed laugh
2000 Silver Frost SVT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
#24288 07/14/02 07:26 PM
mbb41 Offline OP
4000rpm with solid throttle is when it starts on my car.
#24289 07/14/02 07:34 PM
E
E
Interesting,
Normally "ping" will go away the harder you accellerate. When the knock sensor "feels" it, it will retard the timing. Bad gas or perhaps excessive carbon buildup? Do you do a lot of steady state "commuting" driving? If so you might want to take it for a good rip somewhere SAFE.
...Ed
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
#24290 07/15/02 03:19 AM
mbb41 Offline OP
wish I could take it for a good rip. frown I'm still trying to fix my powerloss issues. wink
#24291 07/15/02 04:00 AM
Have you checked all the underhood wires??? If these are cracked it will be the source of your loss of power and maybe even the pinging. Check the wires on the fuel rail....I'll bet you $5 they are cracked. Read this.
This.
and this!
If there is a rattle around 70 mph it may be the sway bar link, if it's bad...it will rattle. The test is to push in the clutch and see if the rattle goes away. If it does....replace it. The parts $9 each (one on each side)and it should take an hour or so to replace both (longer if you aren't too familiar with working on cars).
Good luck!
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile
Moderator of the Florida Contour Enthusiast Group
#24292 07/15/02 12:34 PM
Hey MBB41... if u do a search looking for my posts you'll see that 1/4 of them are about my pinging problems !!!
I have a Zetec.. and it seems I am the only one with the knocking...
The other week I found a cracked/cut vaccum hose... I am in the process of changing it...
I hope that is the cause of my problem....
What are u driving again ?? V6 or the Zetec ??
** CT - USA **
* 96 Contour Gl 2.0
5 Speed Manual / Clarion CD Change
8" Subwoofer & Sony Amp (LOUD !!)
The Cleanest !!!
* 92 Mazda Protege
5 Speed Manual / 1.8
* 94 Yamaha Virago 535
(better than Viagra !!)
#24293 07/15/02 03:35 PM
mbb41 Offline OP
I'm driving both, but the V6 has the "most" of the problems.
