Posts: 181 |
Anybody here from the Gainesville area?
BDSVT
------------------ '99 SVT Blk/mid blue #2414 7/30/99 (a Friday car) 20% metallic tint all around
'99 SE 35% metallic tint all around
'99 SE (Wife's)
Posts: 446 |
I'm up in J'ville
------------------ Shaun D. Parks Red 98 SVT #2214 KKM intake, KKM pedals Momo shift knob Jax, FL
Posts: 181 |
Hey Shaun- I see in your sig you've got the KKM intake and pedals - 2 mods I've been thinking about doing. How do you like them? Any problems with heat soak or moosing?
Brian
'99 SE (Wife's)
Posts: 345 |
Brian, Hi! My daughter's at UF. I just got back from Homecoming/Growl/USC game - great time!
By any chance do you know of a shop in the G'ville area that does custom upholstery work? My daughter has a '94 Escort GT that needs to have the door panels repaired. Replacements cost almost $300 a piece!
Any help would be appreciated. Thanks! AL
BTW-You won't believe the sweet sounds you get with the KKM intake! I moosed badly once it was installed, but for 16 cents, the TH fix took care of the problem permanently.
------------------ Red '98 SVT E0 3098/6535 KKM Elizabethan EGR Plate TH fix Bosch +4s B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid PowerStops and painted calipers all around A6 Side Markers Horn recontent Painted Sail Panels VooDoo Knob and pedals Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates Sway Bar bushings when I get around to it
[This message has been edited by goldsmi (edited November 13, 2000).]
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 181 |
I know there are 2-3 but I can't think of them off the top of my head. My wife put a cigarette burn in the driver's seat of her '99 SE and I've been putting off getting it fixed until she quits smoking. Although, since the 'Tours are disappearing I should probably get on that. I'll see if I can dig up the list of places I found and let you know.
Brian
[This message has been edited by BDSVT (edited November 14, 2000).]
'99 SE (Wife's)
Posts: 345 |
Thanks! Any help would be appreciated. AL
Posts: 181 |
Well, I couldn't find the list I made earlier but a quick search turned up the following:
BOY'S AUTO/BOAT UPHOLSTERY 2808 NE 21ST WAY, GAINESVILLE, FL 32609, (352) 375-6700
GEORGE'S AUTO UPHOLSTERY 4404 NW 13TH ST, GAINESVILLE, FL 32609, (352) 371-0169
L & S AUTO TRIM 5721 NW 13TH ST, GAINESVILLE, FL 32653, (352) 372-8661
BROADWAY UPHOLSTERY 3202 N MAIN ST, GAINESVILLE, FL 32609, (352) 378-7228
Hope this helps! Brian
'99 SE (Wife's)
Posts: 446 |
DBSVT, email me at sparks@mediaone.net for those questions
Anonymous
Unregistered
Anonymous
Unregistered
Hey what part of Jacksonville you from? I live in OP! Iw ould like to check out you SVT sometime, I'm about to get one! Email me at JBY28@yAHOO.COM Originally posted by sparks: I'm up in J'ville
