Posts: 1,036 |
I will not be there on April 6th as I will be on "vacation" up north.
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
Posts: 291 |
I might be able to make it depending on what date is decided on.
I can make the 30th but not the 6th
2000 Silver SE Sport V6 MTX, B&M shifter, SVT exhaust, 75K on the clock.
Posts: 3,180 |
The 30th should work for me.
Posts: 3,223 |
I have a wedding on the 30th but should be able to make it afterward!
-Andy
Posts: 1,507 |
I should be good for the 30th
-- Mike (Moe)Lester -- 98.5 SVT #5486 moesvt@comcast.netGet your a$$ on IM and stop wasting bandwidth!!!!!!
Posts: 3,419 |
The 30th is the day before Easter. I'll try to make it if it is that day, but can't say for sure.
Posts: 1,732 |
Originally posted by PA 3L SVT: The 30th is the day before Easter. I'll try to make it if it is that day, but can't say for sure. Ah, good point....Not sure if I can make it either...
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 3,331 |
99' SVT 86' Toyota Pickup Beater - Tha Daily Driver
Posts: 153 |
WOOHOO!!! A day I can make it.
Antonio, let me know what else you need, I'll bring it.
Silver 1999 SVT #442 of 2760
Posts: 291 |
how late you planning on going ? I have something else in hagerstown until about 5 p.m. but if you are planning on being there late into the day I might go ahead and make the drive up.
