Posts: 1 |
I tried the search option and couldn't find the info. I heard that Porsche had a hand in the design of the Duratec 2.5L V6 Contour motor. Is that true?
Posts: 3,567 |
that was one thing that we were told at the Spring Zing banquet, so it most likey is true.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 878 |
Some of the design work was outsourced to a group of engineers at Porsche, according to Terry Haines.
"Function before fashion."
'96 Contour SE
Posts: 869 |
The contour was designed by ford germany right?
2000 CSVT #1172 of 2150 Toreador Red...Birthday -> 1/4/2000 *Indiglo Gauges *Drop in K&N *Sylvania SilverStar Highs in Lows *Fog light Fix *Pioneer Premier P730 *Sound by Audiobahn *White HVAC Panel *Security via Ungo MS2007 *Elky Mesh Mod
Posts: 1,493 |
The basic CDW27 platform was designed in Europe, yes, but not just Germany. The Duratech is more of a US design, I believe.
I read somewhere that some of the 6 billion cost for the design was due to Ford USA employees flying over to Europe. Supposedly to "help or approve" parts of the program, along with long meetings. Maybe it was these "paid vacations" that drove the costs up?
2000 SE fleet, V6, ATX, ABS, no spoiler, T-Green/tan. Built 01/2000 in MO. Added 12 spoke factory SE rims, K&N. Biggest mod: ESP Plan!
Posts: 3,248 |
terry can best explain but the initial prototype duratecs were built by Porsche and made 250 HP. Ford modified the engine, including "choping off" part of the crank (which may have resulted in the crank whip and our need for the DMD) to shorten the engine to fit. He has posted some pics that you could search for of the prototypes.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 251 |
I wonder how hard it was for these engines to make 250? I don't know how to exactly ask this but before Ford changed the design, did the basic engine setup make that much power? Would the cost have been too high to use the motor in its oringinal configuration if there didn't need to be any modifications to the engine bay?
Curtis Dead 98 Black SVT 92K
Posts: 5,805 |
Porsche engines made 250 hp, fit was a problem and cost....
Posts: 1,053 |
Originally posted by Terry Haines: Porsche engines made 250 hp, fit was a problem and cost.... How could this happen ?? If Ford gave Porsche a spec for size (physical I mean) and cost (and I can't believe that these items weren't discussed beforehand), how did the Porsche engine end up being too big & expensive ??
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course." #9 - Hitting .400 for ever "Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez "The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
Posts: 378 |
Um...things change?
I do not know if this was the case, but when you are developing something the tolerances are going to be smaller than when you mass produce it. So maybe Ford said "It would cost to much to produce that part that accurately" (Something Porsche does and turns the cost over to the consumer) so they change some things so it can be way off but still function fine. But all those mismatched factory parts add up and start killing the output...
Just speculating...don't take me too seriously.
