Posts: 303 |
I just got my SVT back from the dealership for a serpentine belt replacement. The belt had a nick in it, presumably from a rock or something.
Any of you know how much "book time" the belt replacement should be? Dealer charged me 2 hrs labour, plus $69 for the belt. Seems kinda high to me. 2 hrs to change the belt??
Any wisdom appreciated. TIA.
Kerry
99 SVT Contour Silver Frost, #365/2760 91 Isuzu Impulse XS Kammback, Handling By Lotus Victoria, BC, Canada
Posts: 23 |
Kerry, I did mine last weekend. It is a little bit of a pain to do...but it only took me about 30 minutes. That time includes removing the right front wheel and the plastic liners in the fenderwell which give you access to the crank & alternator pulley. I think 2 hours is ridiculous and it's just one of the reasons I never take my car to the dealer or a garage unless I can't handle the job myself. Later.
'95 Ford Contour SE ATX...primarily the wife's car '86 Ford Mustang LX notch 5.0 5-speed...12 second project
Posts: 3,248 |
I had the ford dealer throw a new belt on when they did the DMD. No extra labor charge ..2 birds with 1 stone..
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 237 |
Two hours to replace a serpentine belt is ridiculous!
I can do it faster and I don't have power tools.
Plus you can buy the belt at a local auto parts store for around $20-25. I got mine from Yates/Carquest for $19 plus tax.
1996 Contour SE Sedan 4D (Royal Blue) Duratec V6 2.5L 24-valve DOHC Automatic 75,000 miles No Mods (unless you call the DMD a mod) Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
Posts: 303 |
Thanks for the confirmation, guys. I would have thrown on the DMD, if I had one. Gotta order one next month.
I did the SEARCH and it appears that labour time should be around 30 mins for a dealer with the proper tools. B*stards.
Damn, good thing I haven't paid them yet...they ordered in the dash repair kit, so I get to go in there again in a few days...yikes.
Posts: 1,770 |
2 hours is assinine. With the proper breaker bar for the tensioner, you can do it in 20 min. without taking anything off the car.
Posts: 470 |
The dealer should have a book which dictates how long they can/should charge for changing the belt. And, as everyone has pointed out, anything over 30 minutes is too much.
'99 Black SVT Join the SVTOA Safe Harbour Statement: Anything said above must be interpreted against the background that nothing whatever might occur in the future.
Posts: 304 |
Yes the dealers do have a book. Actually they have two. At least they did when I worked there. One is for non-warranty jobs and one is for warranty work. Guess which one is the more liberal with the hours?  When I worked for Ford in the early/mid 70's, labor was ~$25 - 35/hr IIRC. I worked for three Ford dealers and one Mercedes and they all had different rates. More important to us techs was the percentage of that labor that we received which was between 40 to 50%. We used to get alot of Lincolns and Mercs too because their dealers charged higher labor rates. Anyway guys, front wheel drive cars are not cheap to repair for the most part. Just spread the cost of owning these vehicles over the length of time you own them or the mileage you drive them. It isn't as hard to take that way. Karl
*** It's all about consistency! ***
98 SVT Contour 86 Ranger GT 69 Fiat 850 Sport Spider 67 Formula-S Barracuda
Posts: 1,770 |
Originally posted by 98SVT: It isn't as hard to take that way. It is if they charge you 2 hours for a job that takes 30 min.
Posts: 165 |
As per ALLDATA And Mitchell.. Alotted time for a Ford Certified Technician to replace the belt is .5 Hours... If they are complete idiots then I would say .75 hrs... No more... I would go see the Service Manager and have him show you the book time.
John 1996 Ford Contour Zetec. ~Torreador Red 5 Speed. ~17" Nocturno Rims w/205-40 series tires ~SVT Shift Knob Thanks to Eric ~Custom painted cowl, wipers, mirrors, sail panels ~Color Shifting interior highlights ~Eibach Lowering Springs. ~Pioneer C.D.Player. ~5% Tint on all windows including front window. ~Custom Black Dyed Carpet. ~Fubo Antenna In Middle of roof. ~Shortened Billet Antenna in rear. ~Indiglo BNM Gauges and ~Speedpeople Indiglo HVAC panel. ~High Flow Cat. ~Custom exhaust. ~Custom dyed Steering wheel. **Soon to come** ****Air Cylinders**** **Another TV/DVD Player ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
