Posts: 1,507 |
Headers should be done first!
-- Mike (Moe)Lester -- 98.5 SVT #5486 moesvt@comcast.netGet your a$$ on IM and stop wasting bandwidth!!!!!!
Posts: 3,180 |
Argh, I just talked to Rob at the SHO Shop, they have no MSDS headers in stock, and frankly don't have a clue as to when they'll be able to get them.. Sucks, because they were selling them for $50 less than everyone else.
Ok, so where else might I be able to get these headers in the next 18 days? Help!
Posts: 2,246 |
Well, I will be a runner as well. I mean if my car is under the knife, I guess I will be forced to drive someone's SVT...damn  . Also, is there anything I should buy for you guys to aide in the exhaust install?
David Litsky AIM: DaveL225 My Car
Posts: 597 |
For the guys who want headers done, did you remember to pick up a new set of exhaust manifold gaskets? If not let me know, I can get them pretty cheap.
--Matt
00' SVT Contour, Black and Blue #954 of 2150 Stock....
2003 Red Fire Convertable Cobra due in September...
Posts: 3,331 |
99' SVT 86' Toyota Pickup Beater - Tha Daily Driver
Posts: 3 |
First, I don't even know if i could make it if you all do not mind if i come Second, Do you guys mind if a cougar guy shows up? kevin
2000 Vibrant White Cougar President of Capital NECO
Posts: 1,036 |
Pete, Matt - I should have my exhaust by then so you can count on mine... Has anybody done the euro antenna thing before? I have one that needs to be installed but dont know if it could get done that day, especially if its up on jackstands and all... I can do a lot of work, but Im sure I'll have to do some running as well. Im happy to do whatever helps.
So... Josh = Bassani, Plugs, and STB.
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
Posts: 597 |
Originally posted by Kevin: First, I don't even know if i could make it if you all do not mind if i come Second, Do you guys mind if a cougar guy shows up?
kevin  Sure, Cougars are always welcome. --Matt
Posts: 486 |
Originally posted by David L: woohooo, I will have a 2 hour drive of nothing but pure zetec exhaust note AHAHAHAHAHAHAHAHAH David L, if you want an SVT exhaust, you can have mine, it will be coming off and replaced with a Borla  , not sure how it would sound on a Zetec, but its your if you want it. At least that way I won't have to cut it up and lug it home.
Jesse Beltsville, MD 98.5 Silver Frost SVT
Posts: 2,246 |
Pete already offered me his as well as his SVT rear sway bar. Thanks though. Maybe someone else will come down and want the other exhaust. You got any rims?
