#23507 07/09/02 07:46 AM
V
V
This is a strange couple of question really... but I was just curious. If you have an automatic and you put your car in first, then second, then into drive... will it hurt it to do this on a constant basis? Just curious. Also, I was curious if you put your car in reverse, then put it into neutral(perhaps when backing down a hill), then put it in drive, is that better than just shifting neutral to reverse real fast? Odd questions I know, but something I've been pondering. Thanks for everyones input.
I don't know much about cars. I'm just starting out. That's why I'm here right?
1995 Mercury Mystique GS
2.0L DOHC
Not too much else.
Kyle~
Anything like revving in neutral and dropping it in gear (drive or reverse) is a neutral drop = bad. But manual shifting in your automatic shouldn't be bad but pickup is usually slower than just putting it in drive and flooring it. Or at least that is my experience. wink
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
i manually shift mine every so often, it's good for it(well my baby anyways) and you can go to the red line unlike when it's in drive, unless you have a chip or something
That is what I'm saying. I have a chip and it is pointless manual shifting when the chip changes the shift points anyway. cool
Hector
Mods...I got em'
My profile
I
I
i also do the same...starting out in 1st and taking it through the gears..its fun and gives me a lil change from just flooring it...also has a nice sound...but from what ive heard its not to smart to do it all the time....oh well.... :rolleyes:
Chris
99 V6 Sport/Silver
SVT kit~SVT Dual Ex.~KKM intake~Front & Rear grills painted silver~GTS Headlight covers~Plasma Blue light under dash(removed white bulb)~30 % tints~Tinted Rear Reflector~Wood Grain Kit~Removed door dings~Super White Heads~Plasma blue reverse lights~ blacked out sail panels~painted brakes Blue~complete stereo system~
it depends. Some transmissions are different. I know some of the transmissions, specifically the hydro-mechanical type manually selecting a gear reasults in a higher line pressure that helps reduce slippage off the line, but will also result in firmer shifts as you manually select the next gear.
Like it was mentioned before, don't put the transmission into a gear with the engine reving higher than idle, its not good for it. Just like selecting a forward gear while moving backwards and vice versa.
manual gear selecting can be helpful and even benificial to the transmission especially under severe service like towing a heavy trailer or snow plowing, two things that will not likely be done with your contour.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
V
V
Lol, no, my car isn't going to be pulling a boat or anything. Thanks guys.
2.0L DOHC
Not too much else.
Kyle~
