#231605 06/19/02 03:32 AM
Corey Offline OP
here you go
the bolt is metric either 10 or 12 x 150 (threadpitch)
the puck that is missing is 13/16's high and 2 and 3/8's wide
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
#231606 06/19/02 05:05 AM
I assume the size of the hole in the puck is the same as the bolt.
Do we need to replace a nut as well, or is a piece of the mount threaded eliminating the need for a nut.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
#231607 06/19/02 05:51 AM
i am an idiot.... so im assuming i go to like a home depot and look for this bolt or some hardware store... now wtf is a puck and where would i find something like this
Mike | 98 Silver CSVT
#231608 06/19/02 02:05 PM
Corey Offline OP
yeah jay no need for you to get a nut this time, oops i mean the bolt threads into the mount
mike, a puck is just what i said a puck, like a hockey puck, but with the dimensions i gave, and a hole in the middle.....
you could get one without a hole in the middle and drill one if needbe
i dont know where you could get the puck, but the bolt you could get at a hardware stock, i wouldnt suggest getting the strongest bolt you can get either, cuz if the bolt doesnt break, something else will
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
#231609 06/19/02 03:17 PM
if the bolt is a standard metric bolt then a number will be stamped on the head. like, 8.8, 9.9, 10.1 those numbers indicate the bolts condition of heat treat. Be sure to get a bolt with the same number.
A source of the (puck) would be the urethane body mount bushings that come in body mount kits for things like pick-up trucks. Unfortunately the kits are a little pricey and come with a fairly large assortment of bushings.
I'll keep my eyes peeled during my travels and see what else I can find.
aol IM: madhat1412
#231610 06/19/02 03:30 PM
Does Energy Suspension have anything like that?
88 Grand Marquis
00 SVT Contour (1584)
64 390 FE Big Block
02 Honda Spirit 750
#231611 06/19/02 05:29 PM
thats the name I was looking for. I'm sure that if you get a catalog of the stuff they make you'll find something close, and then it can be trimmed to fit.
aol IM: madhat1412
#231612 06/19/02 05:40 PM
Call SPmotorsports. I think they carry Contour specific stuff from energy suspension.
88 Grand Marquis
64 390 FE Big Block
02 Honda Spirit 750
#231613 06/19/02 07:27 PM
Corey Offline OP
i heard theres no poly mounts made for this mount
theres nothing stamped on the bolt, its a torx head
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
#231614 06/19/02 11:16 PM
what about getting something from ford ?? didnt you mention something like this before Corey?
ford must carry what you need...
Moderated by  baco99, frenchblueC2_dup1
