Page 1 of 3 1 2 3
#231204 06/11/02 03:55 PM
F
F
It only took 6,000 miles eek
Thank god its still under factory warranty. So at 32,000 miles I am having the wheel bearing, and throttle body replaced.
They tried to get me to replace my rear brakes but I wasn't falling for it. Why would my rear brakes go before my front ones? The car stops on a dime. They said "We took the tires off to check the rear brakes and they are down to 3mm...we can replace them for $189.00". They were checking them because the car sometimes sticks after I take the e-brake off and try to go in reverse in the morning. There's a sound as if the brakes are stuck. Then it goes just fine.
In case you are curious the car is at Milbury Ford. I know a lot of you have had problems with them but they have always been good to me and my old Cougar. I bought the Cougar there.
Tim
2000 Ford Contour SVT
#185 of 2150
Black with Tan leather
No mods and none planned
#231205 06/11/02 04:07 PM
Mine's going into Bonnell on Monday for the right front wheel bearing too! Wish it would be under warranty...would save me about $200!
-Rob- '98 E0 Contour SVT #897, T-Red. FOR SALE: '98 E0 CSVT #2663 SilverFrost; stock & in very good condition. $7,800
KKM & BAT Intake Pipe, DIY cool air intake, Resonator deleted, TH fix; short shifter, rear spoiler, hood struts, fog mod, pre-98 sails, dings removed, A4 side-markers, clear head-light corners, T-red chrome front & back. Aussie Bar waiting for installation.
"Monkey is my business...and business is good!"
#231206 06/11/02 04:09 PM
E
E
i gots to bring mine back to bonnell for the sunroof motor still....
waiting for more to go wrong to take full advantage of my deductable
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent*
Please call...
1-800-FOR-ELKY
All proceeds go towards saving CEG
#231207 06/11/02 04:17 PM
F
F
my rear brakes stick like that in the morning too from using the ebrake.
it has always done that since I bought it brand new.
it's not every morning.
more like 1 in every 10 mornings or something like that depending on the weather and whatnot.
Kim
2001 Mercury Cougar C2
1995 Contour GL
Quote: Originally posted by shotwell:
Yeah, I keep checking too. I'm afraid that just as the site goes down my car will burst into flames or something (knocking rapidly on wood)!
#231208 06/11/02 04:20 PM
O
O
What is up with Contours and wheel bearings???? I hear this often on the forums. Mostly for the newer ones (99 or higher). Did they switch to a cheaper part of something????? Now I know Ford would never do anything like that. :rolleyes:
#231209 06/11/02 04:29 PM
F
F
I just want it back and running smoothly. They didn't have the throttle body in stock so I have to wait till tomorrow to get it back.
Tim
#185 of 2150
#231210 06/11/02 04:31 PM
I had the same prob with my Silver CSVT...
:rolleyes:
#231211 06/11/02 06:03 PM
the 99 SVT I currently have, the e-barke sticks when it sits over night, and my other, 2000 SVT did it too from day one with 48 miles on it the back brake would stick. So I'd say that the e-brake sticking and making the pop sound when you start moving is perfectly normal.
The reason they are telling you your rear brakes are worn is becasue there is nothing physically wrong with the car. If they come to you and say "we found nothing wrong," they're afraid you will figure they think you are a dummy who doesn't know a brake rotor from a hot rock.
And 3mm, thats almost nothing, I'll bet that when they tell you the pads are 3mm thick, they are refering to the pad having 3mm more material than the minimum ammount specified in the service manual. I'm sure they will last until the fall. Besides, I recently changed the pads on my SVT, and it did nothing to stop the sticking e-brake.
When the brake sticks like it does for us, there is nothing wrong with the actuation system, it is simply the pad seizing to the rotor
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
#231212 06/11/02 06:07 PM
F
F
you know what I've been noticing lately on mine though is that same rear wheel that has the sticky brake in the morning seems to be squealing when I come to a stop.
anyone else having this problem too?
is it possible there's a rock stuck up in there or something?
I should go look and see if there are scrapes on my rotors.
Kim
1995 Contour GL
#231213 06/11/02 06:46 PM
i saw it up on the lift last night. mine's there too getting its state inspection.
and there is a black on there with a wreck on the driver's front fender. has some big exhaust and a ford banner on the windshield.
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
Page 1 of 3 1 2 3
Moderated by  baco99, frenchblueC2_dup1
