Page 1 of 3 1 2 3
#229339 05/06/02 09:31 PM
mklaro Offline OP
Well as stated in a different post. My CEL came on. Check it with a code reader and it tripped the code....
P0420 CATALYST EFFICIENCY BELOW THRESHOLD (BANK 1)
Upon searching through the CEG. I see that many people have had this issue. Apparently there is an 8 yr. 80k miles warrenty on the Converter.
Does anyone know about this ?
Hey Corey did you ever get your issue resolved ??
I cleared the code so know i have to drive the car to try to get the code to come up again. I have 77k on the car so hopefully I can get this taken care of curtiousy of Ford.
Mike | 98 Silver CSVT
I've been driving with it on for about 20k miles. Still getting 25mpg, still good power. I'll be hitting 97k miles tomorrow. There's nothing to lose sleep over.
Ryan M. Taylor
1996 GL V6 ATX Desert Violet
{__ 15" 98SE 12-spoke wheels, 205/60-15 Pirelli HP Unidirectional Tires __ KKM TrueRev Intake __ Bosch +4's __ Pioneer DEHP4000 __ 9mm Ford Motorsport Wires __ 2.25" Dual Exhaust, Catco Cat, Flowmaster 40 Series, no res __ Mobil 1 5w30 badge mod __ Pilot Millenium Series H.I.D. 55W Fogs __ Xenon 100W Highs __ Intermittent Ford P0420 CEL Option __}
http://rmtaylor.webhop.org
AIM: Vinnland990
if you reset it...the code will come back eventually...i know this wink
since i have a SC on my car i DOUBT they would fix my cats under warrantee, so what i did was get an extra set of manifolds, and gutted them...now they just need to be put on the car cool
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
mklaro Offline OP
well F**k it, I might as well get it taken care of while its on Fords tab. Also i need a sticker, mine has been expired for some time now.. and will i beable to pass without that thing working ?
E
E
Mike, any ford dealer is required by federal law to replace the cats if they STB before 8 yr or 80K mile. i just had all 3 of mine replaced. teh only prob is they take about a week to get the new ones. just bring it in and have it done.
corey, unless they can prove that a mod you did had a direct effect on the damaged part, then the warrty is not void. and since this is a federal warranty i am sure wthey will replace them
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent*
Please call...
1-800-FOR-ELKY
All proceeds go towards saving CEG
elky is right.
there is a federal law that demands dealers to replace the cat. converter under warranty....
so a search on google.com for federal emission warranty or 'clean air act' and you will find MORE than enough info. on it.
good luck! smile
thats ok
i got those nice new manifolds in my basement that need to be used REAL SOON
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
mklaro Offline OP
ohh hell yeah!!!! thanks for the info guys... now as soon as the CEL comes back on im making an appointment and not at Sarat in Agawam.. I think im going to head down to Enfield Ford.
YES the emission system warranty, mandated by the Federal Government is good for 8 yrs 80,000 miles on all cars built after a certain date.
You converters will be replaced at no charge to you.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
H
H
enfield, ct?
cats r replaced only if there's a problem, right?
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Page 1 of 3 1 2 3
Moderated by  baco99, frenchblueC2_dup1
