the story about not changing between motor oil is an oil wise mans tale. You can switch between brands and between synthetic and non-synthetic and you can even mix synthetic and non systhetic.
Yes the covers need to be removed. Simply grab onto them up near the top, squeeze, wiggle and pull down and they'll pop right out. Don't wiggle or squeeze too hard since the clips are plastic and might break.
