Posts: 3,584 |
I wanna see the finished pics of the car, especially the custom made bumper it will have to have so the intercooler will work its best  That little vent on the fender looks really good and he should look into getting the Aussie hood vent mod too, because I'm sure that will thing will need to vent  I do have to echo the comments about the yellow though and ask "WHY :rolleyes: " I wonder if the final drive ratio was changed to higher gearing like a 3.50-3.70, can you say 160mph CSVT
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 4,042 |
Originally posted by Roger R: I wonder if the final drive ratio was changed to higher gearing like a 3.50-3.70, can you say 160mph CSVT The 4.06 final drive is geared to right around 160mph. 143mph is the drag limited speed for the SVT, not gearing limited. John
Administrator
Administrator
Posts: 5,037 |
Originally posted by JVT: Originally posted by AirKnight: [b]I didn't say big, I just said front mounted. My preception was that Chris's kit has top mounted intercooler that's inside the engine bay. I don't think you'll need to have a different bumper if you can have an intercooler that can fit between the bumper and the radiator (sort of like the SVT's oil cooler maybe?). I'm no turbo expert neither, but I'm curious on finding out why all these turbo have different designs.
I doubt there is enough room to put the cooler in between the radiator and the bumper, and if there is, you probably will have a hard time running the piping. (more custom piping, more $$$)
That alone would be a project in itself, not to mention you'd block quite a bit of air that was bound to hit the radiator. What's cooler air good if you're overheating sitting in traffic? Then again, I can't/won't say how that would be affected, since I certainly didn't run any tests w/ a intercooler sitting right in front of the radiator.
IMO (again, not a turbo expert), you get the water/air cooler because of packaging, and the water/air cooler is more efficient (at one point or another) than a front mount air/air intercooler, not to mention probably a lil cheaper.
Ya'll experts, feel free to correct me.
John[/b]You are correct John. We are using a Spearco water/air intercooler that is mounted in the engine bay. As you can plainly see in this example, plumbing a front mounted air/air intercooler is VERY ineffecient. Water/air IC mounted directly to the TB is a very short path compared to this latest example.
Posts: 7 |
I would have to agree with a few of the posters here. That dyno plot is not what you would want to have. The peak HP is nice, but way to Peaky and far up in the range.
I also have to address the other poster who points out "they don't have a mandrel bender" This causes power losses, the piping in this install just plain sucks. check out the connection at the intercooler-the silicone connector is kinked, that is bad. Not what I would expect from a professional shop. Nice peak numbers though. with some work they can smooth it out nicely.
1991 3000GT VR4HKS Super AFR,Greddy ProfecB & Turbo Timer,Gutted Pre Cats, FIPK, C/F Autometer A/F & Boost Gauge, J-Spec transplant, bored 40 over, Wiseco Forged Pistons, Forged rods-shotpeened polished, TEC 17G Turbos, RC550cc,Walbro 255LPH HP, Port-polished heads-port matched Intake, 500+hp 500+lbs torque AWD AWS LSD http://www.importpoweronline.com/ http://www.gtvr4.com/
Posts: 4,899 |
Don't forget everyone, this is more for R&D. A final product would be much more 'non-ghetto' than this. Still can't wait for a finished product.
Posts: 5,296 |
Just wondering, Chris. What about small horizontally mounted air-air IC that goes right below the engine and have some kind of ram air? Like I said, I'm just curious in why you choose what you chose in your kit. Originally posted by Chris Hightower: You are correct John. We are using a Spearco water/air intercooler that is mounted in the engine bay. As you can plainly see in this example, plumbing a front mounted air/air intercooler is VERY ineffecient. Water/air IC mounted directly to the TB is a very short path compared to this latest example.
Administrator
Administrator
Posts: 4,527 |
Originally posted by AirKnight: Just wondering, Chris. What about small horizontally mounted air-air IC that goes right below the engine and have some kind of ram air? Like I said, I'm just curious in why you choose what you chose in your kit.
Originally posted by Chris Hightower: [b]You are correct John. We are using a Spearco water/air intercooler that is mounted in the engine bay. As you can plainly see in this example, plumbing a front mounted air/air intercooler is VERY ineffecient. Water/air IC mounted directly to the TB is a very short path compared to this latest example. [/b]AK, go do some reading about the differences between air to air and water to air intercoolers. You obviously don't understand the dynamics of the situation or the differences between the two types of intercooler.
It's all about balance.
bcphillips@peoplepc.com
Posts: 704 |
Air/Air coolers need free flowing cool air on BOTH sides in order to work right?
Originally posted by 99SESPORT: First off, if somebody is grabbing your nuts, your gonna do everything you can to get him off... And sitting there telling him politely
"Please let go of my nuts, sir?"
Posts: 7,329 |
Originally posted by AirKnight: I don't think you'll need to have a different bumper if you can have an intercooler that can fit between the bumper and the radiator
(sort of like the SVT's oil cooler)
I'm no turbo expert neither Did you miss the entire part about overheating the engine do to lack of flow through the radiator??? Have you ever looked at the clearance between the front bumper cover and the front support? Where would the pipes route through! (you'll notice the SVT pictured is missing a chunk of its front fender!) Ahem... The SVT uses a sandwich oil cooler mounted behind the oil filter. It's water to oil. Not air to oil! BTW - that's a double negative...
Posts: 7,329 |
Originally posted by Rara: AK, go do some reading about the differences between air to air and water to air intercoolers. You obviously don't understand the dynamics of the situation or the differences between the two types of intercooler. bling-bling factor over intelligent, thought out design... Give me function over fashion anyday...
